Have a room with a heated floor and a 2kw heater in place. Both use different temp probes and are set via the platform: generic_thermostat
Usually to get into comfort zone the formula is quite simple 2kw heater as a base temp and heated floor as base + 5c.
Is there a way to combine this two into one thermostat with the use of custom cards and built in HA but control both of them from one lovelace card?
nickrout
(Nick Rout)
February 2, 2019, 10:00pm
2
A template sensor combined with a generic thermostat.
Can you emphasize on the logic how it should be done?
Template sensor = base-5 and then combine both heaters under generic?
nickrout
(Nick Rout)
February 3, 2019, 7:09am
4
I am not quite sure what your formula means
Do you mean that the recipe for getting the house to the best temp is to put on a 2kw heater and set the floor target temp to the desired temp + 5degrees.
nickrout
(Nick Rout)
February 3, 2019, 8:43am
6
Then i possibly misunderstood the problem. It is bedtime, so I will sleep on it!
