Bump! Any recent developments?
Any chance you could share your postman collection with me? I just moved to HA to manage my home & would like to try this againā¦
I am very close. I called the initial pairing to get the token and stored that in a variable to use it in the pairing confirm step & successfully paired to get the arToken, but this is where my success stops. I canāt figure out how to send a button or a voice command, even though I have the arToken and can see in easy pair that my UUID is paired. I hope I can sort this out with the help of your collectionā¦
thank you for your previous help with the UUID. I couldnāt make sense of it & of course it needs to be a new one for the ādeviceā Iām pairing.
Here is a postman collection that should work. Just replace the clientDeviceId GUID in the Authorize call with one of your own choosing.
"info": {
"_postman_id": "d166bb50-1c24-41cf-aaa6-b0ee54891244",
"name": "Comcast",
"schema": "https://schema.getpostman.com/json/collection/v2.1.0/collection.json",
"_exporter_id": "5593788"
"item": [
"name": "Authorize",
"event": [
"listen": "test",
"script": {
"exec": [
"pm.test(\"Status code is 200\", function () {\r",
" pm.response.to.have.status(200);\r",
"});\r",
"pm.test(\"Get auth token\", function () {\r",
" var jsonData = pm.response.json();\r",
" pm.globals.set(\"token\", jsonData.token);\r",
" pm.globals.set(\"pairingCode\", jsonData.pairingCode);\r",
"});\r",
"type": "text/javascript"
"request": {
"method": "POST",
"header": [],
"body": {
"mode": "raw",
"raw": "{\"partner\":\"comcast\",\"clientDeviceId\":\"9e0ed919-a606-46d0-8a1d-2521e64010a0\"}",
"options": {
"raw": {
"language": "json"
"url": {
"raw": "https://accrem.apps.cloud.comcast.net/api/v1/pairing/start",
"protocol": "https",
"host": [
"accrem",
"apps",
"cloud",
"comcast",
"net"
"path": [
"api",
"v1",
"pairing",
"start"
"response": []
"name": "Poll for pairing",
"event": [
"listen": "test",
"script": {
"exec": [
"});\r",
" if (jsonData.status === \"CONFIRMED\") {\r",
" pm.globals.set(\"exp\", jsonData.exp);\r",
" pm.globals.set(\"arToken\", jsonData.arToken);\r",
" }\r",
"});\r",
"request": {
"method": "POST",
"header": [
"key": "Authorization",
"value": "Bearer {{token}}",
"type": "text"
"body": {
"mode": "raw",
"options": {
"raw": {
"language": "json"
"url": {
"raw": "https://accrem.apps.cloud.comcast.net/api/v1/pairing/confirm",
"host": [
"accrem",
"apps",
"cloud",
"comcast",
"net"
"path": [
"api",
"v1",
"pairing",
"confirm"
"response": []
"name": "Get Devices",
"event": [
"listen": "test",
"script": {
"exec": [
"});\r",
"pm.test(\"Get first device\", function () {\r",
" pm.globals.set(\"deviceId\", jsonData.devices[0].id);\r",
" pm.globals.set(\"deviceName\", jsonData.devices[0].name);\r",
"});\r",
"request": {
"method": "POST",
"header": [
"value": "Bearer {{arToken}}",
"type": "text"
"url": {
"raw": "https://accrem.apps.cloud.comcast.net/api/v1/devices",
"host": [
"accrem",
"apps",
"cloud",
"comcast",
"net"
"path": [
"api",
"v1",
"devices"
"response": []
"name": "Refresh token",
"event": [
"listen": "test",
"script": {
"exec": [
"});\r",
"pm.test(\"Get token\", function () {\r",
"});\r",
"request": {
"method": "POST",
"header": [
"type": "text"
"url": {
"raw": "https://accrem.apps.cloud.comcast.net/api/v1/auth/token/refresh",
"host": [
"accrem",
"apps",
"cloud",
"comcast",
"net"
"path": [
"api",
"v1",
"auth",
"token",
"refresh"
"response": []
"name": "Process Key",
"request": {
"method": "POST",
"header": [
"type": "text"
"body": {
"mode": "raw",
"raw": "{\r\n \"vcode\":\"ENTER\"\r\n}",
"options": {
"raw": {
"language": "json"
"url": {
"raw": "https://accrem.apps.cloud.comcast.net/api/v1/processKey",
"host": [
"accrem",
"apps",
"cloud",
"comcast",
"net"
"path": [
"api",
"v1",
"processKey"
"response": []
"name": "Process Text",
"request": {
"method": "POST",
"header": [
"type": "text"
"body": {
"mode": "raw",
"raw": "{\r\n \"cmd\":\"ESPN\"\r\n}",
"options": {
"raw": {
"language": "json"
"url": {
"raw": "https://accrem.apps.cloud.comcast.net/api/v1/text",
"host": [
"accrem",
"apps",
"cloud",
"comcast",
"net"
"path": [
"api",
"v1",
"text"
"response": []
Hi all -
Hoping for some help getting the xfinity authorization tokens refreshed using automations and rest posts in home assistant. Iāve successfully got the pairing completed using RestER and have successfully integrated commands using the arToken in Home Assistant. Doing the pairing though - Iām out of ideas on why this doesnāt work. Tried all the rest sensor formats and every value template I can think of. What am I missing?
- resource: https://accrem.apps.cloud.comcast.net/api/v1/pairing/start
method: POST
headers:
Content-Type: application/json
payload: '{"partner":"comcast","clientDeviceId":"3b7c0ff0-935f-47bd-a7f6-5c09d6627952"}'
- name: "Xfinity Pairing"
unique_id: xfinity_adpative_remote_pairing
value_template: '{{ value_json["token"] }}'
Control4 has a local IP integration. Has anyone with both HA & C4 tried to reverse engineer the integration?
