Hi guys!
I’m running HA in a docker container using the provided docker-compose.yml file on an RPi 4B: Alternative - Home Assistant
The problem occurs using this switch:
switch:
- platform: command_line
switches:
display_power:
command_on: "/opt/vc/bin/vcgencmd display_power 1"
command_off: "/opt/vc/bin/vcgencmd display_power 0"
command_state: "vcgencmd display_power"
friendly_name: Display Power
When toggling the switch I get this error message:
Logger: homeassistant.components.command_line.switch
Source: components/command_line/switch.py:118
Integration: command_line (documentation, issues)
First occurred: 16:05:20 (1 occurrences)
Last logged: 16:05:20Command failed: /opt/vc/bin/vcgencmd display_power 1
I also tried /usr/bin/vcgencmd
and just vcgencmd
but it’s neither working from HA - in the Shell all commands work properly!
Isn’t HA container allowed to run the command vcgencmd
or can I fix this somehow?
Thank you for your support!
