Command failed: /usr/bin/vcgencmd
Hi guys!
I’m running HA in a docker container using the provided docker-compose.yml file on an RPi 4B: Alternative - Home Assistant
The problem occurs using this switch:
switch:
  - platform: command_line
    switches:
      display_power:
        command_on: "/opt/vc/bin/vcgencmd display_power 1"
        command_off: "/opt/vc/bin/vcgencmd display_power 0"
        command_state: "vcgencmd display_power"
        friendly_name: Display Power
When toggling the switch I get this error message:
Logger: homeassistant.components.command_line.switch
Source: components/command_line/switch.py:118
Integration: command_line (documentation, issues)
First occurred: 16:05:20 (1 occurrences)
Last logged: 16:05:20
Command failed: /opt/vc/bin/vcgencmd display_power 1
I also tried /usr/bin/vcgencmd and just vcgencmd but it’s neither working from HA - in the Shell all commands work properly!
Isn’t HA container allowed to run the command vcgencmd or can I fix this somehow?
Thank you for your support!
vcgencmd won’t be available inside the container. You should be able to ssh from the container to the host and run the command that way.
Search the forum, there have been several topics about this already.
