Command Line Configuration yaml update
i cant work out how to change my existing confaiguration.yaml to support the new command line usage? anyones help would be very much appreciated, have tried all sorts but cant work it out!
This is my current syntax:
  - platform: command_line
    scan_interval: 40
    switches:
      garage_down_test:
        command_on: echo -e " \02\00" | nc 192.168.1.124 17494
        command_off: echo -e "!\02\00" | nc 192.168.1.124 17494
#        command_state: echo -e "\x24" | nc -q 1 192.168.1.124 17494
        friendly_name: Test command over tcp
      in1out1:
        command_on: echo -e -n "1B1." | nc 192.168.1.21 4001
      in1out2:
        command_on: echo -e -n "1B2." | nc 192.168.1.21 4001
        friendly_name: Lounge TV SKY Q
      in1out3:
        command_on: echo -e -n "1B3." | nc 192.168.1.21 4001
      in1out4:
        command_on: echo -e -n "1B4." | nc 192.168.1.21 4001
      in1out5:
        command_on: echo -e -n "1B5." | nc 192.168.1.21 4001
      in1out6:
        command_on: echo -e -n "1B6." | nc 192.168.1.21 4001
      in1out7:
        command_on: echo -e -n "1B7." | nc 192.168.1.21 4001
      in1out8:
        command_on: echo -e -n "1B8." | nc 192.168.1.21 4001
      in2out1:
        command_on: echo -e -n "2B1." | nc 192.168.1.21 4001
      in2out2:
        command_on: echo -e -n "2B2." | nc 192.168.1.21 4001
        friendly_name: Lounge TV SKY Q MINI
      in2out3:
        command_on: echo -e -n "2B3." | nc 192.168.1.21 4001
      in2out4:
        command_on: echo -e -n "2B4." | nc 192.168.1.21 4001
      in2out5:
        command_on: echo -e -n "2B5." | nc 192.168.1.21 4001
      in2out6:
        command_on: echo -e -n "2B6." | nc 192.168.1.21 4001
      in2out7:
        command_on: echo -e -n "2B7." | nc 192.168.1.21 4001
      in2out8:
        command_on: echo -e -n "2B8." | nc 192.168.1.21 4001
      in3out1:
        command_on: echo -e -n "3B1." | nc 192.168.1.21 4001
      in3out2:
        command_on: echo -e -n "3B2." | nc 192.168.1.21 4001
        friendly_name: Lounge TV CCTV
      in3out3:
        command_on: echo -e -n "3B3." | nc 192.168.1.21 4001
      in3out4:
        command_on: echo -e -n "3B4." | nc 192.168.1.21 4001
      in3out5:
        command_on: echo -e -n "3B5." | nc 192.168.1.21 4001
      in3out6:
        command_on: echo -e -n "3B6." | nc 192.168.1.21 4001
      in3out7:
        command_on: echo -e -n "3B7." | nc 192.168.1.21 4001
      in3out8:
        command_on: echo -e -n "3B8." | nc 192.168.1.21 4001
      in4out1:
        command_on: echo -e -n "4B1." | nc 192.168.1.21 4001
      in4out2:
        command_on: echo -e -n "4B2." | nc 192.168.1.21 4001
        friendly_name: Lounge TV SHIELD
      in4out3:
        command_on: echo -e -n "4B3." | nc 192.168.1.21 4001
      in4out4:
        command_on: echo -e -n "4B4." | nc 192.168.1.21 4001
      in4out5:
        command_on: echo -e -n "4B5." | nc 192.168.1.21 4001
      in4out6:
        command_on: echo -e -n "4B6." | nc 192.168.1.21 4001
      in4out7:
        command_on: echo -e -n "4B7." | nc 192.168.1.21 4001
      in4out8:
        command_on: echo -e -n "4B8." | nc 192.168.1.21 4001
      in5out1:
        command_on: echo -e -n "5B1." | nc 192.168.1.21 4001
      in5out2:
        command_on: echo -e -n "5B2." | nc 192.168.1.21 4001
        friendly_name: Lounge TV PLAYSTATION
      in5out3:
        command_on: echo -e -n "5B3." | nc 192.168.1.21 4001
      in5out4:
        command_on: echo -e -n "5B4." | nc 192.168.1.21 4001
      in5out5:
        command_on: echo -e -n "5B5." | nc 192.168.1.21 4001
      in5out6:
        command_on: echo -e -n "5B6." | nc 192.168.1.21 4001
      in5out7:
        command_on: echo -e -n "5B7." | nc 192.168.1.21 4001
      in5out8:
        command_on: echo -e -n "5B8." | nc 192.168.1.21 4001
      in6out1:
        command_on: echo -e -n "6B1." | nc 192.168.1.21 4001
      in6out2:
        command_on: echo -e -n "6B2." | nc 192.168.1.21 4001
      in6out3:
        command_on: echo -e -n "6B3." | nc 192.168.1.21 4001
      in6out4:
        command_on: echo -e -n "6B4." | nc 192.168.1.21 4001
      in6out5:
        command_on: echo -e -n "6B5." | nc 192.168.1.21 4001
      in6out6:
        command_on: echo -e -n "6B6." | nc 192.168.1.21 4001
      in6out7:
        command_on: echo -e -n "6B7." | nc 192.168.1.21 4001
      in6out8:
        command_on: echo -e -n "6B8." | nc 192.168.1.21 4001
      in7out1:
        command_on: echo -e -n "7B1." | nc 192.168.1.21 4001
      in7out2:
        command_on: echo -e -n "7B2." | nc 192.168.1.21 4001
      in7out3:
        command_on: echo -e -n "7B3." | nc 192.168.1.21 4001
      in7out4:
        command_on: echo -e -n "7B4." | nc 192.168.1.21 4001
      in7out5:
        command_on: echo -e -n "7B5." | nc 192.168.1.21 4001
      in7out6:
        command_on: echo -e -n "7B6." | nc 192.168.1.21 4001
      in7out7:
        command_on: echo -e -n "7B7." | nc 192.168.1.21 4001
      in7out8:
        command_on: echo -e -n "7B8." | nc 192.168.1.21 4001
      in8out1:
        command_on: echo -e -n "8B1." | nc 192.168.1.21 4001
      in8out2:
        command_on: echo -e -n "8B2." | nc 192.168.1.21 4001
      in8out3:
        command_on: echo -e -n "8B3." | nc 192.168.1.21 4001
      in8out4:
        command_on: echo -e -n "8B4." | nc 192.168.1.21 4001
      in8out5:
        command_on: echo -e -n "8B5." | nc 192.168.1.21 4001
      in8out6:
        command_on: echo -e -n "8B6." | nc 192.168.1.21 4001
      in8out7:
        command_on: echo -e -n "8B7." | nc 192.168.1.21 4001
      in8out8:
        command_on: echo -e -n "8B8." | nc 192.168.1.21 4001
      tabletapphass:
        command_on: "/usr/bin/curl -X GET http://192.168.1.203:8765/?hass"
      tabletappcctv:
        command_on: "/usr/bin/curl -X GET http://192.168.1.203:8765/?cctv"
      tabletappwake:
        command_on: "/usr/bin/curl -X GET http://192.168.1.203:8765/?wake"
      tabletappunlock:
        command_on: "/usr/bin/curl -X GET http://192.168.1.203:8765/?unlock"
      heatrecovery:
        command_on: "/usr/bin/curl -X GET http://192.168.1.123/io.cgi?DOA14=10"
        command_off: "/usr/bin/curl -X GET http://192.168.1.123/io.cgi?DOI14"
        command_state: "/usr/bin/curl -X GET http://192.168.1.123/io.cgi?"
        value_template: '{{ value | regex_match ("^(......)(...............)([1])") }}'
        friendly_name: Heat Recovery Boost
      heatrecoveryboost:
        command_on: "/usr/bin/curl -X GET http://192.168.1.123/io.cgi?DOA14"
        friendly_name: Heat Recovery Boost NEW
      heatrecoverysw:
        command_on: "/usr/bin/curl -X GET http://192.168.1.123/io.cgi?DOA15"
        command_off: "/usr/bin/curl -X GET http://192.168.1.123/io.cgi?DOI15"
        value_template: '{{ value | regex_match ("^(......)(................)([1])") }}'
        friendly_name: Heat Recovery Power
      garage_lights:
        command_on: "/usr/bin/curl -X GET http://192.168.1.124/io.cgi?DOA1"
        command_off: "/usr/bin/curl -X GET http://192.168.1.124/io.cgi?DOI1"
        command_state: "/usr/bin/curl -X GET http://192.168.1.124/io.cgi?"
        value_template: '{{ value | regex_match ("^(......)(.)([1])") }}'
        friendly_name: Garage Internal Lights
      gateway_lights:
        command_on: "/usr/bin/curl -X GET http://192.168.1.124/io.cgi?DOA4"
        command_off: "/usr/bin/curl -X GET http://192.168.1.124/io.cgi?DOI4"
        value_template: '{{ value | regex_match ("^(......)(....)([1])") }}'
        friendly_name: Entrance Gates Lights
      garage_downlights:
        command_on: "/usr/bin/curl -X GET http://192.168.1.124/io.cgi?DOA2"
        command_off: "/usr/bin/curl -X GET http://192.168.1.124/io.cgi?DOI2"
        value_template: '{{ value | regex_match ("^(......)(..)([1])") }}'
        friendly_name: Garage Downlights
      pole_light:
        command_on: "/usr/bin/curl -X GET http://192.168.1.124/io.cgi?DOA5"
        command_off: "/usr/bin/curl -X GET http://192.168.1.124/io.cgi?DOI5"
        value_template: '{{ value | regex_match ("^(......)(.....)([1])") }}'
        friendly_name: Telegraph Pole Light
      sprinklers:
        command_on: "/usr/bin/curl -X GET http://192.168.1.124/io.cgi?DOA6"
        command_off: "/usr/bin/curl -X GET http://192.168.1.124/io.cgi?DOI6"
        value_template: '{{ value | regex_match ("^(......)(......)([1])") }}'
        friendly_name: Sprinklers
      porch_lights:
        command_on: "/usr/bin/curl -X GET http://192.168.1.123/io.cgi?DOA9"
        command_off: "/usr/bin/curl -X GET http://192.168.1.123/io.cgi?DOI9"
        value_template: '{{ value | regex_match ("^(......)(..........)([1])") }}'
        friendly_name: Porch Lights
      landing:
        command_on: "/usr/bin/curl -X GET http://192.168.1.123/io.cgi?relay=8"
        command_off: "/usr/bin/curl -X GET http://192.168.1.123/io.cgi?relay=8"
        command_state: "1"
        friendly_name: Landing
      hall:
        command_on: "/usr/bin/curl -X GET http://192.168.1.123/io.cgi?relay=11"
        command_off: "/usr/bin/curl -X GET http://192.168.1.123/io.cgi?relay=11"
        command_state: "1"
        friendly_name: Hall
      study:
        command_on: "/usr/bin/curl -X GET http://192.168.1.123/io.cgi?relay=10"
        command_off: "/usr/bin/curl -X GET http://192.168.1.123/io.cgi?relay=10"
        command_state: "1"
        friendly_name: Study
      floodlight:
        command_on: "/usr/bin/curl -X GET http://192.168.1.123/io.cgi?relay=16"
        command_off: "/usr/bin/curl -X GET http://192.168.1.123/io.cgi?relay=16"
        command_state: "1"
        friendly_name: Floodlight
      dining_pendant:
        command_on: "/usr/bin/curl -X GET http://192.168.1.123/io.cgi?relay=5"
        command_off: "/usr/bin/curl -X GET http://192.168.1.123/io.cgi?relay=5"
        command_state: "1"
        friendly_name: Dining Pendant
      dining_down:
        command_on: "/usr/bin/curl -X GET http://192.168.1.123/io.cgi?relay=2"
        command_off: "/usr/bin/curl -X GET http://192.168.1.123/io.cgi?relay=2"
        command_state: "1"
        friendly_name: Dining Downlights
      kitchen_bar:
        command_on: "/usr/bin/curl -X GET http://192.168.1.123/io.cgi?relay=4"
        command_off: "/usr/bin/curl -X GET http://192.168.1.123/io.cgi?relay=4"
        command_state: "1"
        friendly_name: Kitchen Bar Lights
      kitchen_underunits:
        command_on: "/usr/bin/curl -X GET http://192.168.1.123/io.cgi?relay=3"
        command_off: "/usr/bin/curl -X GET http://192.168.1.123/io.cgi?relay=3"
        command_state: "1"
        friendly_name: Kitchen Under Units
      kitchen_down:
        command_on: "/usr/bin/curl -X GET http://192.168.1.123/io.cgi?relay=7"
        command_off: "/usr/bin/curl -X GET http://192.168.1.123/io.cgi?relay=7"
        command_state: "1"
        friendly_name: Kitchen Downlights
      lounge_lamps:
        command_on: "/usr/bin/curl -X GET http://192.168.1.123/io.cgi?relay=6"
        command_off: "/usr/bin/curl -X GET http://192.168.1.123/io.cgi?relay=6"
        command_state: "1"
        friendly_name: Lounge Lamps
      lounge_ceiling:
        command_on: "/usr/bin/curl -X GET http://192.168.1.123/io.cgi?relay=1"
        command_off: "/usr/bin/curl -X GET http://192.168.1.123/io.cgi?relay=1"
        command_state: "1"
      front_gates:
        command_on: "/usr/bin/curl -X GET http://192.168.1.124/io.cgi?DOA7=2"
        command_off: ""
        command_state: "1"
        friendly_name: Driveway Gates
      garage_door:
        command_on: "/usr/bin/curl -X GET http://192.168.1.124/io.cgi?DOA3=2"
        command_off: ""
        command_state: "1"
        friendly_name: Garage Door
      cctv_tv_popup:
        command_on: "/usr/bin/curl -X GET http://192.168.1.52:5443/index.html?cctvpopenable"
        command_off: "/usr/bin/curl -X GET http://192.168.1.52:5443/index.html?cctvpopdisable"
        command_state: ""
        friendly_name: CCTV TV PopUp
      loungetv_skyqmain:
        command_on: "/usr/bin/curl -X GET http://192.168.1.52:5443/index.html?loungetv_skyqmain"
        command_off: ""
        command_state: ""
        friendly_name: Sky Q Main
      loungetv_skyqmini:
        command_on: "/usr/bin/curl -X GET http://192.168.1.52:5443/index.html?loungetv_skyqmini"
        command_off: ""
        command_state: ""
        friendly_name: Sky Q Mini
      loungetv_cctv:
        command_on: "/usr/bin/curl -X GET http://192.168.1.52:5443/index.html?loungetv_cctv"
        command_off: ""
        command_state: ""
        friendly_name: CCTV
      loungetv_nvidia:
        command_on: "/usr/bin/curl -X GET http://192.168.1.52:5443/index.html?loungetv_nvidia"
        command_off: ""
        command_state: ""
        friendly_name: Nvidia
      loungetv_ps4:
        command_on: "/usr/bin/curl -X GET http://192.168.1.52:5443/index.html?loungetv_ps4"
        command_off: ""
        command_state: ""
        friendly_name: PS4
      loungetv_monpc:
        command_on: "/usr/bin/curl -X GET http://192.168.1.52:5443/index.html?loungetv_monpc"
        command_off: ""
        command_state: ""
        friendly_name: Monitoring PC
      bedroomtv_105:
        command_on: "/usr/bin/curl -X GET http://192.168.1.52:5443/index.html?BedroomTV_channel5"
        command_off: ""
        command_state: ""
        friendly_name: Bedroom TV Channel 5
      bedroomtv_cbeebies:
        command_on: "/usr/bin/curl -X GET http://192.168.1.52:5443/index.html?BedroomTV_cbeebies"
        command_off: ""
        command_state: ""
        friendly_name: Bedroom TV CBeebies
What éxactly is the problem?
