Command Line Cover default state unknown after 0.109.0 upgrade
my command line cover configuration was working fine prior to 0.109.0 upgrade.
My issue is that now after a reboot the state of each cover is unknown, which greys out the up / down buttons. This was never an issue as I had never configured the command_state variable.
After upgrade it now defaults to unknown and causes the problem. I have tried:
command_state: 50
but this does not work. When manually adjusting the state to 50 everything works fine until the next reboot.
Any thoughts.
Appreciate your replies.
Markus
This has been reported multiple times in the 0.109 release topic.
Yep, same for MQTT/others.
Thanks Tom, I had a good look around but must have missed it… so no solution at this time I take it.
Thanks for the info Adam, didn’t notice it on my MQTT as I have states updates for all of them.
Yep, I have retained state topics for all of them but still greyed out. Has worked perfectly for years.
