totolino
(totolino)
1
Hi guys. I really need your help with my rollershutters.
edit: I think my question should be, How do I call a service in command line cover.
I’m on newest hassbian.
Whats working:
I created a shell_command for every rollershutter with up stop and down like this
shell_command:
rollup1all: '/home/pi/rollremote/codeSend 876785752875'
rolldown1all: '/home/pi/rollremote/codeSend 876785752876'
rollstop1all: '/home/pi/rollremote/codeSend 876785752877'
When I trigger the following rule the rollershutter will go down!
- action:
- service: shell_command.rolldown1all
alias: down
condition: []
- above: '60'
entity_id: sensor.temperature_158d000171998b
platform: numeric_state
Here comes the part which is not working:
cover:
- platform: command_line
covers:
gruppe3_alle:
command_open: shell_command.rollup1all
command_close: shell_command.rolldown1all
command_stop: shell_command.rollstop1all
What am I doing wrong with the command-line cover?!
VDRainer
2
If you want to use the shell_command service, you have to use the Template Cover
In the command_line cover you have to call your scripts directly.
cover:
covers:
gruppe3_alle:
command_open: '/home/pi/rollremote/codeSend 876785752875'
command_close: '/home/pi/rollremote/codeSend 876785752876'
command_stop: '/home/pi/rollremote/codeSend 876785752877'
totolino
(totolino)
3
awesome. works with the template cover thank you very much
totolino
(totolino)
4
What is the easiest way to resend the command several times to make it more reliable?
VDRainer
5
Make a script an call it from the template cover.
script:
cover_down:
sequence:
- delay: '00:00:01'
totolino
(totolino)
6
perfect. can I ignore the state of the cover so home assistant does not “grey out” the commands.
VDRainer
7
Yep! position_template: 50
