Howdy all- I’m just getting started with Home Assistant and am trying to program a switch to send a TCP message to a group of devices when toggled. I’m able to get the command to work just fine from a terminal, however when I plug it into a switch in the configuration.yaml, it doesn’t seem to send. Is there something I’m missing?
Below is how it is listed in the configuration.yaml file. Any input or suggestions are very much appreciated.
Thanks,
Amina
command_line:
- switch:
command_on: for i in {200..206}; do echo -e "0" | nc -w 1 192.168.0.$i 8080; done
command_off: echo "off"
It’s possible that the command line integration does not allow pipes. I know for sure that the shell command integration doesn’t.
Speaking of the shell command integration, that would seem to be a more appropriate than a command line switch for what you’re trying to do here.
The way to get around the limitation of not being able to use pipes is to move the command (pipes and all) into a shell script that you save somewhere in /config
or a subdirectory thereof. Then you can just reference that shell script in configuration.yaml
Thanks much for the suggestions- I created a shell script and used the shell command integration to add them into configuration.yaml, and also changed the switch over to an input_select in order to select through different colors. The input selector seems to be working just fine, however I keep getting an error code 2 when the script is executed.
I’ve tried the following to remedy the error code:
- Using “<<<” instead of pipes in the nc command to rule out whether the issue was related to use of pipes; same error code.
- Using a python script instead of a shell script to send the TCP commands; same error code.
- Ensuring the script permissions are executable; same error code.
- Testing that just ‘echo “test”’ works when everything else is commented out in the shell script; no error code.
It seems like there’s still some permissions issue or command I’m using which isn’t allowed, but I can’t seem to figure out what it is.
Below is my configuration.yaml as well as the shell script. Any additional input is much appreciated!
shell_command:
led_red: sh /root/homeassistant/shell_scripts/ledCloud_send_tcp_message.sh "0"
led_orange: sh /root/homeassistant/shell_scripts/ledCloud_send_tcp_message.sh "1"
led_yellow: sh /root/homeassistant/shell_scripts/ledCloud_send_tcp_message.sh "2"
led_green: sh /root/homeassistant/shell_scripts/ledCloud_send_tcp_message.sh "3"
led_blue: sh /root/homeassistant/shell_scripts/ledCloud_send_tcp_message.sh "4"
led_indigo: sh /root/homeassistant/shell_scripts/ledCloud_send_tcp_message.sh "5"
led_purple: sh /root/homeassistant/shell_scripts/ledCloud_send_tcp_message.sh "6"
led_pink: sh /root/homeassistant/shell_scripts/ledCloud_send_tcp_message.sh "7"
led_rainbow: sh /root/homeassistant/shell_scripts/ledCloud_send_tcp_message.sh "8"
led_white: sh /root/homeassistant/shell_scripts/ledCloud_send_tcp_message.sh "9"
led_off: sh /root/homeassistant/shell_scripts/ledCloud_send_tcp_message.sh ":"
input_select:
multi_state_switch:
options:
- Red
- Orange
- Yellow
- Green
- Blue
- Indigo
- Purple
- Pink
- Rainbow
- White
initial: Rainbow
icon: mdi:toggle-switch
automation:
- alias: Red
triggers:
platform: state
entity_id: input_select.multi_state_switch
to: 'Red'
actions:
- action: shell_command.led_red
- alias: Orange
triggers:
platform: state
to: 'Orange'
actions:
- action: shell_command.led_orange
- alias: Yellow
triggers:
platform: state
to: 'Yellow'
actions:
- action: shell_command.led_yellow
- alias: Green
triggers:
platform: state
to: 'Green'
actions:
- action: shell_command.led_green
- alias: Blue
triggers:
platform: state
to: 'Blue'
actions:
- action: shell_command.led_blue
- alias: Indigo
triggers:
platform: state
to: 'Indigo'
actions:
- action: shell_command.led_indigo
- alias: Purple
triggers:
platform: state
to: 'Purple'
actions:
- action: shell_command.led_purple
- alias: Pink
triggers:
platform: state
to: 'Pink'
actions:
- action: shell_command.led_pink
- alias: Rainbow
triggers:
platform: state
to: 'Rainbow'
actions:
- action: shell_command.led_rainbow
- alias: White
triggers:
platform: state
to: 'White'
actions:
- action: shell_command.led_white
#!/bin/bash
# Assign the first argument to a variable
MESSAGE="$1"
# Loop through the IP addresses
for IP in 200 201 202 203 204 205 206; do
nc -w 1 192.168.0.$IP 8080 <<< "$MESSAGE"
#echo "$MESSAGE" | nc 192.168.0.$IP 8080 || echo "fail" &
done
