I am trying to use a switch created through the command_line integration in my automation but I always get the return code 127 on its execution. I have home assistant running in a docker container. Please see the attached image.
I also want to point out that I was able to use the CPU temperature sensor through the command line integration described in their documentation. Since some things work and some doesn’t, I am pretty sure that something is wrong in the way I’m trying to use the switch. I would really appreciate some help here.
Please let me know if you need any additional info.
