Command Line Light - Use the command line to control an "unsmart" device
Hi there,
I love Home Assistant and the many possibilities given to control unsmart devices in my home.
I like to work with the command line plug-ins, so that I can integrate other Apps like LIRC or Fhem in my Home Assistant Project.
I would like to see a feature, where I can control an IR controlled light bulb with the Home Assistant software.
Because I don’t really understand programming that much, I friendly ask you to help me to get a workaround for this problem.
Seems like a basic thing, not sure why it’s not in there already. There is a Command Line Everything, it would be easy to implement a Command Line Light with the same on/off/state scripts.
Any particular reason this doesn’t exists?
Hi there, I’m so sorry to put this topic again to TOP but I have a question about that.
Configuring the command_line switch and switches is terrific simple and awesome. But it is not equally simple to set a light (simple light) in the same way. Is there any one that did it and he could help me to do the same?
Didn’t search did you? Custom Proxy Platform - Easily Convert Switches to Lights!
Ops… my bad! Thanks a lot
