Hi
I’m trying to send a curl command via command line sensor, but it’s dropping the double quotes " around the URL and Authorization.
This is the command: -
command: 'curl -s "https://my.tado.com/api/v1/me" -H "Authorization: Bearer {{ state_attr(''sensor.tado_auth'', ''access_token'') }}" '
For clarity, these are double quotes “https… …me” “Authorization… … }}”
and these are two lots of single quotes ‘‘sensor.tado_auth’’, ‘‘access_token’’
and there is a single quote at the beginning and end.
I’ve tried doubling up the double quotes, just in case, but that didn’t work.
I have another call, surrounded by single quotes, and with the url in double quotes, that works perfectly, but it doesn’t need an Authorization token
The log shows: -
Command failed: curl -s https://my.tado.com/api/v1/me -H Authorization: Bearer eyJhbGciOZD7JfPdL1V4vY526ZY-UCGg
Whereas if I use a terminal, and manually add back in the quotes it works perfectly: -
curl -s "https://my.tado.com/api/v1/me" -H "Authorization: Bearer eyJhbGciOZD7JfPdL1V4vY526ZY-UCGg"
(I’ve shortened the token significantly)
Thanks in advance for any help
Jonathan
