rooot.999
(Rooot 999)
April 2, 2022, 12:37pm
1
I am trying to unlock my door through HA, it’s a straightforward HTTPS link but in the last variable of the link “date=” we need to assign the current date, which I think is the one that is causing issues with my below code:
switch:
- platform: command_line
switches:
home_door_four:
command_on: "curl -k https://api.ttlock.com/v3/lock/unlock?clientId=xxxxx&accessToken=xxxxx&lockId=xxxxx&date={{ (now().timestamp() | int * 1000 ) }}"
command_off: "curl -k https://api.ttlock.com/v3/lock/lock?clientId=xxxxx&accessToken=xxxxx&lockId=xxxxx&date={{ (now().timestamp() | int * 1000 ) }}"
tom_l
April 2, 2022, 1:19pm
2
command_on
and command_off
do not support templates.
You could create two shell commands (that do support templates) and use them as the turn_on and turn_off actions in a template switch.
rooot.999
(Rooot 999)
April 2, 2022, 2:44pm
3
Could you explain more, or is there any way to get the currentmillis without using formula?
tom_l
April 3, 2022, 1:43am
4
No, you have to use a template. Which the command line swtich does not support. So…
Create two shell commands. Use the curl commands you already have.
shell_command:
home_door_four_on: "curl -k https://api.ttlock.com/v3/lock/unlock?clientId=xxxxx&accessToken=xxxxx&lockId=xxxxx&date={{ (now().timestamp() | int * 1000 ) }}"
home_door_four_off: "curl -k https://api.ttlock.com/v3/lock/lock?clientId=xxxxx&accessToken=xxxxx&lockId=xxxxx&date={{ (now().timestamp() | int * 1000 ) }}"
Test if these work by calling them in the Developer Tools / Services page. If they do work then create your template switch using the shell commands:
switch:
switches:
home_door_four:
turn_on:
service: shell_command.home_door_four_on
turn_off:
service: shell_command.home_door_four_off
If you can get state feedback from the switch with a command you can add that to the switch too. Read the page I linked to.
