The only reason I want a command line script over the template script is that it has the right ui (two buttons vs a toggle).
Use case:
TV
on: call a script with several ir blasts
off: same deal
through voice I want to call tv on /tv off vs two different script names.
Can you call a HA script through the command line script?
Maybe assumed state helps you out? https://home-assistant.io/docs/configuration/customizing-devices/
~Cheers
Perfect, exactly what it was looking for. Thanks!
