(which is working perfectly on the command line) into a proper command for a command_line sensor?
I tried every possible constellation but HA refuses to create the sensor (config check fails). I’m pretty sure I ran into the famous quote/double quote issue with command_line sensors. What’s the allround solution to that problem?
Error loading /config/configuration.yaml: while parsing a block mapping
in "/config/integrations/system_statistics.yaml", line 803, column 5
expected <block end>, but found '<scalar>'
in "/config/integrations/system_statistics.yaml", line 809, column 68
(where 68 is the first appearing ")
escaping the "s does not work using double quotes instead of single ones on the outside did not work
Nice. Thanks for that improvement. Does this work for advanced commands too where multiple pipes are used? In other words: dropping the cat is the only iteration I can achieve? Like
