Hello
i have a relè and i activate and activate it with this commands and it works
switches:
relay1bagno:
friendly_name: ReleBagno1
command_on: curl -s ‘http://192.168.1.50:8081/command=set_active?124’
command_off: curl -s ‘http://192.168.1.50:8081/command=set_deactive?124’
command_state: curl http://192.168.1.50:8081/command=get?element?124
value_template: >
{{value_json.letocrono_status.status}}
icon_template: >
{% if value_json.letocrono_status.status == 1 %} mdi:toggle-switch
{% else %} mdi:toggle-switch-off
{% endif %}
this command (command_state: curl http://192.168.1.50:8081/command=get?element?124) give me this result:
<letocrono_status>
<‘elemento id=“45” type=“8” status=“1” currentvalue=“0” title=“Letto” label_value=“mV” id_group=“115” currenttextvalue="" des_group=“Camera da Letto”/’>
if the relay is on the status is = 1 , if the relay is off the status is = 0
the value template:
value_template: >
icon_template: >
{% endif %}
This is the result on Developer Tools if i check the entity:
icon: >-
<?xml version="1.0" encoding="UTF-8"?>‘’’
<letocrono_status>
Letto” /’>
</letocrono_status>
friendly_name: Luce Camera Letto
I would like to change the icon status but it don’t work.
Any suggest?
Thank you
