…which is 50 and an integer - or is it a string
I want the output to be output -1 (more precisely: output = output -1). That does not work. If I do this calculation, the command_line sensor won’t be created at all:
value_template: >-
{% if (value | int(0) > 0) %}
{{ value -1 }}
{% endif %}
not working
{{ value == ((value | int(0)) -1) }}
{% endif %}
also not working
Only without the calculation the sensor is created (but of course with a wrong value - one too much):
value_template: >-
{{ value }}
{% endif %}
working
How can I do this simple math calculation in the value_template section?
Invalid config for [sensor.command_line]: invalid template (TemplateSyntaxError: expected token 'end of statement block', got '%') for dictionary value @ data['value_template']. Got '{% if value|is_number %}\n {{ value |int -1 }}\n{% else % %}\n unavailable\n{% endif %}\n'. (See ?, line ?).
I’ll try it without the second % at the end of the else line
Update: Now it works. If you’d like to fix that typo in your post I’ll thankfully mark that as solution.
Thank you!
Bonus question:
can you tell me why we don’t need to specify a default for the int here? Is that only necessary for template sensors? I thought that would be good (or meanwhile required) behaviour - but not sure bout those command_line sensors…
