I’m trying to create command line sensor which will be using some jinja2 variables. I want to edit it in future in easy way. Unfortunately I’m getting strange errors during command execution.
Here is my test sensor:
- platform: command_line
scan_interval: 300 # 5 min
command: >
{% set array = [ '0x086bd7fffef1b8da' ] %}
{% set number = 12%}
echo -n "Test sensor; " && echo -n "array: [{{ array }}]; " && echo -n "Number: {{ number }}"
When I hit “RELOAD COMMAND LINE ENTITIES” in Configuration tab two things happen:
/bin/sh: {%: not found
is written intoCore
logs - Sensor state is refreshed but first {% %} block is ignored
When I add {% %}
(empty block) at the beginning of command then after reload message is still logged into Core
logs but array
variable is initialized.
It looks like only first {% block is ignored.
Do you have any ideas why this is happening?
