chrbratt
(Chrbratt)
September 1, 2022, 9:36pm
1
HomeWizard Energy p1 meter works great and exactly as intended. But want the possibility to use command line to access the telegram between the meter, and p1 port to accsess more data then the intigration has. Entities for amp as an example.
This is what the telegram data shows.
http://10.x.x.xx/api/v1/telegram
No json here, ;( what to do ?
/AUX5U41SEH13F10024
0-0:96.1.0(38303034363937333432342748313031363723763032)
0-0:1.0.0(220901203330W)
1-0:1.8.0(000509.671*kWh)
1-0:2.8.0(000000.000*kWh)
1-0:3.8.0(000000.897*kvarh)
1-0:4.8.0(000222.363*kvarh)
1-0:1.7.0(0000.088*kW)
1-0:2.7.0(0000.000*kW)
1-0:3.7.0(0000.000*kvar)
1-0:4.7.0(0000.190*kvar)
1-0:21.7.0(0000.017*kW)
1-0:22.7.0(0000.000*kW)
1-0:41.7.0(0000.051*kW)
1-0:42.7.0(0000.000*kW)
1-0:61.7.0(0000.020*kW)
1-0:62.7.0(0000.000*kW)
1-0:23.7.0(0000.000*kvar)
1-0:24.7.0(0000.000*kvar)
1-0:43.7.0(0000.000*kvar)
1-0:44.7.0(0000.097*kvar)
1-0:63.7.0(0000.000*kvar)
1-0:64.7.0(0000.089*kvar)
1-0:32.7.0(233.9*V)
1-0:52.7.0(230.2*V)
1-0:72.7.0(234.1*V)
1-0:31.7.0(000.0*A)
1-0:51.7.0(000.6*A)
1-0:71.7.0(000.4*A)
- name: P1 Test
platform: command_line
command: 'curl -k --silent "http://10.x.x.xx/api/v1/telegram"'
scan_interval: 10
This dosent work. Max length is 255 characters as shown in the log.
Goal is to get every value in the telegram as a single entiti.
chrbratt
(Chrbratt)
September 2, 2022, 8:37pm
3
It worked perfectly, thank you very much for the quick reply and an easy solution
chrbratt
(Chrbratt)
September 2, 2022, 10:25pm
4
I ended up with this
Huge thanks @DCSBL
rest:
- authentication: basic
scan_interval: 5
resource: http://10.0.1.11/api/v1/telegram
- name: "Cumulative Active Import"
unit_of_measurement: kWh
state_class: "total_increasing"
value_template: "{{ (value|regex_findall_index('1\\-0\\:1\\.8\\.0\\([0-9.]*')).split('(',1)[-1].strip() }}"
device_class: "energy"
- name: "Cumulative Active Export"
value_template: "{{ (value|regex_findall_index('1\\-0\\:2\\.8\\.0\\([0-9.]*')).split('(',1)[-1].strip() }}"
- name: "Cumulative Reactive Import"
unit_of_measurement: kvarh
value_template: "{{ (value|regex_findall_index('1\\-0\\:3\\.8\\.0\\([0-9.]*')).split('(',1)[-1].strip() }}"
- name: "Cumulative Reactive Export"
value_template: "{{ (value|regex_findall_index('1\\-0\\:4\\.8\\.0\\([0-9.]*')).split('(',1)[-1].strip() }}"
- name: "Momentary Active Import"
value_template: "{{ (value|regex_findall_index('1\\-0\\:1\\.7\\.0\\([0-9.]*')).split('(',1)[-1].strip() }}"
- name: "Momentary Active Export"
value_template: "{{ (value|regex_findall_index('1\\-0\\:2\\.7\\.0\\([0-9.]*')).split('(',1)[-1].strip() }}"
- name: "Momentary Reactive Import"
value_template: "{{ (value|regex_findall_index('1\\-0\\:3\\.7\\.0\\([0-9.]*')).split('(',1)[-1].strip() }}"
- name: "Momentary Reactive Export"
value_template: "{{ (value|regex_findall_index('1\\-0\\:4\\.7\\.0\\([0-9.]*')).split('(',1)[-1].strip() }}"
- name: "Momentary Active Import Phase 1"
value_template: "{{ (value|regex_findall_index('1\\-0\\:21\\.7\\.0\\([0-9.]*')).split('(',1)[-1].strip() }}"
- name: "Momentary Active Export Phase 1"
value_template: "{{ (value|regex_findall_index('1\\-0\\:22\\.7\\.0\\([0-9.]*')).split('(',1)[-1].strip() }}"
- name: "Momentary Active Import Phase 2"
value_template: "{{ (value|regex_findall_index('1\\-0\\:41\\.7\\.0\\([0-9.]*')).split('(',1)[-1].strip() }}"
- name: "Momentary Active Export Phase 2"
value_template: "{{ (value|regex_findall_index('1\\-0\\:42\\.7\\.0\\([0-9.]*')).split('(',1)[-1].strip() }}"
- name: "Momentary Active Import Phase 3"
value_template: "{{ (value|regex_findall_index('1\\-0\\:61\\.7\\.0\\([0-9.]*')).split('(',1)[-1].strip() }}"
- name: "Momentary Active Export Phase 3"
value_template: "{{ (value|regex_findall_index('1\\-0\\:62\\.7\\.0\\([0-9.]*')).split('(',1)[-1].strip() }}"
- name: "Momentary Reactive Import Phase 1"
value_template: "{{ (value|regex_findall_index('1\\-0\\:23\\.7\\.0\\([0-9.]*')).split('(',1)[-1].strip() }}"
- name: "Momentary Reactive Export Phase 1"
value_template: "{{ (value|regex_findall_index('1\\-0\\:24\\.7\\.0\\([0-9.]*')).split('(',1)[-1].strip() }}"
- name: "Momentary Reactive Import Phase 2"
value_template: "{{ (value|regex_findall_index('1\\-0\\:43\\.7\\.0\\([0-9.]*')).split('(',1)[-1].strip() }}"
- name: "Momentary Reactive Export Phase 2"
value_template: "{{ (value|regex_findall_index('1\\-0\\:44\\.7\\.0\\([0-9.]*')).split('(',1)[-1].strip() }}"
- name: "Momentary Reactive Import Phase 3"
value_template: "{{ (value|regex_findall_index('1\\-0\\:63\\.7\\.0\\([0-9.]*')).split('(',1)[-1].strip() }}"
- name: "Momentary Reactive Export Phase 3"
value_template: "{{ (value|regex_findall_index('1\\-0\\:64\\.7\\.0\\([0-9.]*')).split('(',1)[-1].strip() }}"
- name: "Voltage Phase 1"
unit_of_measurement: V
value_template: "{{ (value|regex_findall_index('1\\-0\\:32\\.7\\.0\\([0-9.]*')).split('(',1)[-1].strip() }}"
- name: "Voltage Phase 2"
value_template: "{{ (value|regex_findall_index('1\\-0\\:52\\.7\\.0\\([0-9.]*')).split('(',1)[-1].strip() }}"
- name: "Voltage Phase 3"
value_template: "{{ (value|regex_findall_index('1\\-0\\:72\\.7\\.0\\([0-9.]*')).split('(',1)[-1].strip() }}"
- name: "Current Phase 1"
unit_of_measurement: A
value_template: "{{ (value|regex_findall_index('1\\-0\\:31\\.7\\.0\\([0-9.]*')).split('(',1)[-1].strip() }}"
- name: "Current Phase 2"
value_template: "{{ (value|regex_findall_index('1\\-0\\:51\\.7\\.0\\([0-9.]*')).split('(',1)[-1].strip() }}"
- name: "Current Phase 3"
value_template: "{{ (value|regex_findall_index('1\\-0\\:71\\.7\\.0\\([0-9.]*')).split('(',1)[-1].strip() }}"
