Hello everyone,
Due to recent changes in the Tesla API, we are now limited in the number of commands we can send to the car each day. I use my excess solar power to charge my car, which results in numerous commands being sent daily.
When this limit is reached, every command sent by Home Assistant fails, and the following kind of trace appears in the log:
2024-05-30 14:51:39.968 ERROR (MainThread) [homeassistant.core] Error executing service: <ServiceCall number.set_value (c:01HZ4RW0FQDBY0138RP91VDRGS): value=6.0, entity_id=['number.titine_charging_amps']>
My Goal
I am trying to set up a command line sensor that counts the number of these traces in the log and triggers an automation when the count reaches a certain threshold. So far, I have this for the sensor :
# 5. Command Line.
command_line:
- sensor:
name: Titine failed power adjustment
command: 'grep "^$(busybox date -d@"$(( `busybox date +%s`))" "+%Y-%m-%d %H")" home-assistant.log | grep "Error executing service: <ServiceCall number.set_value" | grep "titine" | wc -l '
This works fairly well, but it only counts the number of errors present in the current hour, not for the past hour. For example, if the time is 2:20 PM, it counts the errors between 2:00 PM and 2:20 PM, instead of between 1:20 PM and 2:20 PM as I would prefer.
I have minimal knowledge of bash. I’ve tried reading about BusyBox, grep, awk, and other tools, but I’m quite lost.
Does anyone have an idea on how to improve my sensor?
