Hi all,
I have been following instructions for changing the Sensor to command_line.
most of what I have change works with the exception of the below. I know there must be some simple change I need to make however, in all my searches, I am not able to see these specific errors.
- [automatic_add] is an invalid option for [command_line]
- [resources] is an invalid option for [command_line]
- [display_options] is an invalid option for [command_line]
- [sensors] is an invalid option for [command_line]
I know they all must relate to a similar fix but need help/ pointing at the website I need to fix this. Any ideas please?
My code is below: -
in configuration.yaml
command_line: !include 001-sensor.yaml
then in sensor.yaml
- sensor:
automatic_add: true #[automatic_add] is an invalid option for [command_line].####################
- sensor:
resources: #[resources] is an invalid option for [command_line].####################
- type: disk_use_percent
arg: /home
- type: memory_use_percent
- type: processor_use
- type: last_boot
- type: load_1m
- type: load_5m
- type: load_15m
- type: network_in
arg: eth0
- type: network_out
arg: eth0
- sensor:
display_options: # [display_options] is an invalid option for [command_line].#############
- 'date_time_iso'
- sensor:
sensors: # [sensors] is an invalid option for [command_line].#############
apc_output_watt:
friendly_name: "APC Output Watt"
unit_of_measurement: 'W'
value_template: "{{ states('sensor.apc1500_output_current')|float * states('sensor.apc1500_output_voltage')|float }}"
- sensor:
local_wether_temp:
friendly_name: "Local Temperature"
unit_of_measurement: '°C'
value_template: "{{ state_attr('weather.home', 'temperature') }}"
