I’m using a command_line sensor to monitor a status of a service running on my system. It works ok when system is starter or the monitored service is restarted but it does not update when the service is stopped (which is the most interesting event for me). My config is the following:
- platform: command_line
name: "CA350 service status"
command: "service ca350 status"
scan_interval: 30
The command line service ca350 status
returns ca350 is not running.
or ca350 is running as pid xxx.
where xxx
is the pid.
I have also just realized that there is an error in the log when the service is stopped:
Logger: homeassistant.components.command_line
Source: components/command_line/__init__.py:41
Integration: command_line (documentation, issues)
First occurred: 2:49:19 PM (58 occurrences)
Last logged: 3:08:20 PM
Command failed: service ca350 status
I have also tried with command line binary sensor:
binary_sensor:
command: 'service ca350 status'
value_template: >-
{% if value[6:16] == 'is running' %}
running
{% else %}
stopped
{% endif %}
payload_on: 'running'
payload_off: 'stopped'
name: CA350 service binary
Again, when the service is running it works ok but when it is stopped the error in the log is written and sensor is not updated:
Logger: homeassistant.helpers.entity
Source: helpers/template.py:567
First occurred: 4:06:20 PM (1 occurrences)
Last logged: 4:06:20 PM
Update for binary_sensor.ca350_service_binary fails
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/helpers/entity.py", line 278, in async_update_ha_state
await self.async_device_update()
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/helpers/entity.py", line 474, in async_device_update
raise exc
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/components/command_line/binary_sensor.py", line 108, in update
value = self._value_template.render_with_possible_json_value(value, False)
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/helpers/template.py", line 535, in render_with_possible_json_value
return run_callback_threadsafe(
File "/usr/local/lib/python3.8/concurrent/futures/_base.py", line 432, in result
return self.__get_result()
File "/usr/local/lib/python3.8/concurrent/futures/_base.py", line 388, in __get_result
raise self._exception
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/util/async_.py", line 53, in run_callback
future.set_result(callback(*args))
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/helpers/template.py", line 567, in async_render_with_possible_json_value
return self._compiled.render(variables).strip()
File "/srv/homeassistant/lib/python3.8/site-packages/jinja2/environment.py", line 1090, in render
self.environment.handle_exception()
File "/srv/homeassistant/lib/python3.8/site-packages/jinja2/environment.py", line 832, in handle_exception
reraise(*rewrite_traceback_stack(source=source))
File "/srv/homeassistant/lib/python3.8/site-packages/jinja2/_compat.py", line 28, in reraise
raise value.with_traceback(tb)
File "<template>", line 1, in top-level template code
TypeError: 'NoneType' object is not subscriptable
Any suggestion how to get the status of the service when it is not running instead of the error? Or can I trigger an automation based on this error entry?
