I have made sure that the code I am using as the command works on my venv, as I have read that as being a potential issue in other posts. The “todays_events.txt” file is also readable by anyone.
I can’t quite figure out what the problem is with this, any ideas? Thanks
Do you happen to know if this file updates in home assistant? Like if I were to make a change to the file, would HA see the change or would I have to restart HA for the change to take effect?
