Command_line ssh failed on HA supervised
Guys can someone help me.
trying to run command_line and connect to my proxmox server from the VM running supervised HA. Its keep on giving me
Warning: Identity file /root/.ssh/id_rsa not accessible: No such file or directory. [email protected]: Permission denied (publickey).
unsure where to put id_rsa on HA docker or there are some other way to do it? Help
from the VM terminal I can run the SSH command and connect to the Proxmox machine no problem
- platform: command_line
  command: 'ssh -i /root/.ssh/id_rsa [email protected] cat /sys/class/hwmon/hwmon0/temp1_input 2> /config/command.log'
  value_template: "{{ value | int / 1000 }}"
  unit_of_measurement: "°C"
Create a .ssh hidden folder under config. This works for me.
shell_command.yaml
  switchbot_updates: 'ssh -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no -i /config/.ssh/id_ha [email protected] node /home/pi/bin/mqtt/switchbot/scan.js'
Take a look at this, should help
Thanks guys, I just thinking about that and get your messages. It works
