Hello all,
can I use the Command Line Switch to ssh into a second rpi to stop and start a service?
Or is there maybe a different comonent which support this?
Daranto
Hello all,
Daranto
You’ll want to have SSH keys set up from your HASS pi, but I don’t see a reason this wouldn’t work.
http://www.linuxproblem.org/art_9.html
Use like:
ssh username@other-host 'sudo service whatever stop/start'
Good luck!
thanks for the info.
here is my config:
- platform: command_line
switches:
reboot_hyperion:
command_on: "ssh [email protected] reboot"
command_off: "ssh [email protected] reboot"
When I use the switch I get the following error:
homeassistant.components.switch.command_line: Command failed: ssh [email protected] reboot
From the first pi its possible for me to ssh into the second one without any password. I also tried a local command. The same error appears.
Maybe someone know whats wrong with the switch.
Daranto
You’ll need to change it to:
switches:
reboot_hyperion:
command_on: "ssh [email protected] 'reboot'"
command_off: "ssh [email protected] 'reboot'"
Also, depending on who HASS is running as, you might need to specify the key file for login. You can do so with the -i flag:
ssh -i /home/user/.ssh/id_rsa
http://www.shellhacks.com/en/Running-Commands-on-a-Remote-Linux-Server-over-SSH
thx it works now.
