I lost hours of time, before I realized that the command_line
integration doesn’t support templating for the commands. It would be great, as it would allow users to compose commands based on some entity data.
For example this string works great in the dev tools -> template
and in a shell_command
, but the content of input_text.token
is not injected in case of a ‘command_line’. There the string stays literally the same:
'/usr/bin/curl -s -X GET -H "Content-Type: application/json" -H "Authorization: Bearer {{state_attr("input_text.token", "token")}}" http://192.168.178.xx:8123/api/states/switch.power_on_off'
