Hallo forum,
apologies, a total yaml newbee here…
I have the latest HA running on a Pi 4 with docker. It scanned my network and several things were found and integrated. Looks good.
Now I want to do some command line stuff (shell commands) and I stumbled over yaml (which seems a strange “language” …)
I have a little “Balkonkraftwerk” with a Deye micro inverter which data is available in the local network. I found some code snippets in the net and tried to copy that but I admit I don’t understand the concept of separated “sensor”, “template” and all the requirements that come with it. Why do I have to put things in the configuration.yaml and most stuff goes into the home-assistant_v2.db ?
Anyway, for testing I just read the temperature value from a zigbee sensor via curl and use it as an energy value. This code is now in my configuration.yaml:
# Command line sensors
command_line:
- sensor:
unique_id: sensor_test
# command: echo 12.43
command: curl -s http://192.168.1.51:8080/api/A2F0894703/sensors/8 | grep -oP '(?<=\"temperature\":)\w+'
unit_of_measurement: 'kWh'
device_class: energy
value_template: "{{value}}"
scan_interval: 60
template:
- sensor:
state: "{{ states('sensor.sensor_test') if states('sensor.sensor_test') | float(default=0) }}"
unit_of_measurement: kWh
unique_id: test_value
Finally the sensor “test” works (shown with a value in the dashboard sensor section) but the template “Test_Value” shows “unbekannt” in the dashboard.
Is this the correct “new” style?
Why do I need a template at all?
Why can’t a template include a command: to be executed?
Why is in the sensor section a value_template at all? Could that value be handled by the template section? And also the state.
Single or doubled quotes? no quotes on command: ?
In general I am missing some “real world” example code in the ha documentation.
Thanks for some hints ![]()
