good evening is good week to all. sorry if i am too long but i want to be precise.
for the past few days I have had a problem connecting a sensor bme280 temperature humidity and pressure. and also a temperature probe ds9b20.
I created a mqtt raspimqtt user not to be original. then the user password… and under the nodered module I have the topics that happen to me and I can manage them (export via a file, graphs, gauges).
but when I want to have the topics recognized as a sensor entity. I have a message
temperature exterieure
INFORMATIONS PARAMÈTRES LIÉES
Cette entité (“sensor.temperature_exterieure”) n’a pas d’ID unique, par conséquent ses paramètres
ne peuvent pas être gérés à partir de l’interface utilisateur. Consultez le documentation pour plus de
détails.
I put the lines in configuration.yaml I also put
value_template: {{sensor.temperature_exterior}} and by repeating I have an error that blocks the remarrying.
mqtt:
- name: "temperature exterieure"
state_topic: "home/ESP_1/DS18b20-28bb473a19197/tempExt"
which is copied but changing the values…
when I put before the 4 lines in configuration.yaml
mqtt:
username: "mqtt"
password: "eripot;eofk"
I have a duplicate error in vscode. is there an LTS version like it is for lmde or fedora linux.
thank you for your answer. And good week
