Communication with Locks
This is in relation to zwave locks. I’ve been working with HA for a few months now and love whats been done so far and the flexibility.
My problem is that when building a custom interface to add and remove lock codes from locks there are a few things missing.
  1. The getlockcode service is not useful because you cannot actually get the code that is added to the lock as it comes back encrypted etc…
  2. You cannot verify a code has been added to the lock even though Zwave does respond with a success HA does not seem to capture that event.
  3. Locks like Schlage have to follow a regex type pattern i.e. first 4 - 6 digits cannot be the same as an existing code on the lock. If we cant get the lock code no method to compare or match against regex.
  4. If we could store secrets via node-red or templating or if we could hash input_number variables I could simply store lock codes within HA as a secret and grab those values to perform compares on and store the value in HA after being added to the lock. I’m not comfortable storing a door lock code in HA as a input_number as it stands.
