Home Assistant Community Add-on: ADB - Android Debug Bridge
Download the contents of this androidtv folder and put them in /config/custom_components/androidtv.
But you can also help by testing out the ADB commands in my previous post using the androidtv.adb_command service.
Updated to hassio 91.0.
I have removed the custom component androidtv. Running Android Debug Bridge - Home Assistant
Getting this error message.
Unable to install package androidtv==0.0.14: Failed building wheel for pycryptodome python-jose-cryptodome 1.3.2 has requirement pycryptodome<3.4.0,>=3.3.1, but you’ll have pycryptodome 3.8.1 which is incompatible. pyrebase4 4.3.0 has requirement oauth2client==4.1.2, but you’ll have oauth2client 4.0.0 which is incompatible. broadlink 0.9 has requirement pycryptodome==3.4.11, but you’ll have pycryptodome 3.8.1 which is incompatible. Command “/usr/local/bin/python3 -u -c “import setuptools, tokenize;file=‘/tmp/pip-install-y5t2jq0m/pycryptodome/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(‘\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-record-cqqy5d69/install-record.txt --single-version-externally-managed --prefix --compile --user --prefix=” failed with error code 1 in /tmp/pip-install-y5t2jq0m/pycryptodome/
I’ll fix this.
Same error after updating to 0.91
same error, can we get around this by using it as a custom component again until it’s fixed?
Yes.
Pull request: Remove pycryptodome requirement for Android TV #22552
Code: androidtv
Dear, someone here guide me.
I would like to turn on my androidtv box with broadlink.
How to add custom command in turn on command provided in new config.
:tada: Release v0.3.1
Full Changelog
Changed
  • :arrow_up: Upgrades base image to v3.1.0
  • :sparkles: Adds network port description
  • :hammer: Simplifies add-on code logic
Questions? Join our Discord server! https://discord.me/hassioaddons
Enjoying my add-ons? Consider supporting my work: https://patreon.com/frenck
Not sure when it stopped to work, but does anyone have a woking intent for twitch?
My latest one dont seem to work anymore, all the other ones i have (youtube, kodi and so on) works still.
{"entity_id" :"media_player.shield", "command": "am start -a android.intent.action.VIEW -d -n tv.twitch.android.app/tv.twitch.android.apps.TVLandingActivity"}
It might be since there was an update of twitch to the new GUI on the shield?
I use an app called STBEmu and it has these colored coded buttons that some Android Boxes have on their remote: Yellow, Green, Blue and Red
Anyone knows the codes for these? Tried the following but it doesn’t work…
  - type: horizontal-stack
    cards:
      - type: custom:card-modder
        card:
          type: entity-button
          icon: mdi:disk
          entity: media_player.shield
          hold_action: none
          tap_action:
            action: call-service
            service: androidtv.adb_command
            service_data:
              entity_id: media_player.shield
              command: "PROG_BLUE"
        style:
          background-color: rgba(56,60,69,1)
          border-radius: 20px
          border: solid 3px rgba(118,185,0,1)
          box-shadow: 3px 3px rgba(0,0,0,0.4)
        card:
          type: entity-button
          icon: mdi:disk
          hold_action: none
          tap_action:
            service_data:
              command: "PROG_GREEN"
        style:
          border-radius: 20px
        card:
          type: entity-button
          icon: mdi:disk
          hold_action: none
          tap_action:
            service_data:
              command: "PROG_RED"
        style:
          border-radius: 20px
        card:
          type: entity-button
          icon: mdi:disk
          hold_action: none
          tap_action:
            service_data:
              command: "PROG_YELLOW"
        style:
          border-radius: 20px
I think that because it is an emulation app, you have to map these buttons within the application (settings->configure key maps->BTN_RED to long press 1 etc…) and then use the mapped button for the command
https://developer.android.com/reference/android/view/KeyEvent.html#KEYCODE_PROG_BLUE
Try using either of the following as the command for blue:
  • 'KEYCODE_PROG_BLUE'
  • 'input keyevent 186'
:tada: Release v0.4.0
Full Changelog
This is a general maintenance release that upgrades both ADB & the base image used.
:hammer: Changes
  • :arrow_up: Upgrades add-on base image to 3.1.1
  • :arrow_up: Upgrades adb to 1:8.1.0+r23-5~18.04
Hi there,
I had adb addon worked but after upgrade to newest HA and Newest ADB addon, it stopped work.
I have error HA log:
Could not connect to NVIDIA TV at 192.168.0.230:5555 using ADB server at 192.168.0.250:5037
Platform androidtv not ready yet. Retrying in 150 seconds.
And on ADB addon there are constantly that messages:
[12:41:12] INFO: Starting the Android Debug Bridge server...
adb I 05-08 12:41:12  4832  4832 adb_auth_host.cpp:416] adb_auth_init...
adb I 05-08 12:41:12  4832  4832 adb_auth_host.cpp:174] read_key_file '/root/.android/adbkey'...
adb I 05-08 12:41:12  4832  4832 adb_auth_host.cpp:391] adb_auth_inotify_init...
[12:51:11] INFO: Connecting to device: 192.168.0.230...
connected to 192.168.0.230:5555
adb I 05-08 12:51:11  4832  4832 adb_auth_host.cpp:467] Calling send_auth_response
[12:51:13] INFO: Starting the Android Debug Bridge server...
adb I 05-08 12:51:13  4872  4872 adb_auth_host.cpp:416] adb_auth_init...
adb I 05-08 12:51:13  4872  4872 adb_auth_host.cpp:174] read_key_file '/root/.android/adbkey'...
adb I 05-08 12:51:13  4872  4872 adb_auth_host.cpp:391] adb_auth_inotify_init…
My config is very simple:
"devices": [
"192.168.0.230"
"reconnect_timeout": 600
What went wrong?
That worked thanks!
same issue here. it stopped working after updating ADB addon.
I have the same error log
I have the same issue. After updating the add-on, I got the same error message. Both devices, my Nvidia Shield as well as the Amazon Fire TV are not available anymore.
:tada: Release v0.4.1
Full Changelog
This release fixes an issue with the Android Debug Bridge crashing on start (mainly ARMv7/Raspberry Pi).
It does this by downgrading the adb package since there is no workaround available.
No functionality is lost by this downgrade from the perspective of this add-on.
:hammer: Changes
  • :ambulance: :arrow_down: Downgrades adb to 7.0.0+r33-2 (#12)
Thanks @frenck for very quick fix.
Hope people know snapshots, usually there is always possibility to roll back addon, however always remember or setup automation :wink: to make snapshot before upgrade.
As a noob I learnt that hard way but now I am smart :wink:
How to automate backup before update of any addon as well as homeassistant?
Guide
