Community Hass.io Add-on: AppDaemon2
depend on how good you are with programming javascript, html and CSS :wink:
Zero experience
then it will be VERY difficult for you :wink:
:tada: Release v1.1.0
Full Changelog
Added
  • Enable the REST API port for AppDaemon #9 (@vork)
  • Adds add-on icon and logo
  • Warns the user when not using the Hass.io Proxy address
  • Adds support for auto-configuring Hass.io API security key
Changed
  • Updates base image to v1.3.3
  • Sets HA URL to Hass.io proxy address by default
  • Updates AppDaemon docs URL in README
Hi Frenck,
After updating to 1.1.0, my Dashboard does not command switches any more. The status of each is wrong and nothing happens if I press any button. logs showing below errors. What should I do?
Error handling request
File “/usr/lib/python3.6/site-packages/aiohttp/web_protocol.py”, line 381, in start
resp = await self._request_handler(request)
File “/usr/lib/python3.6/site-packages/aiohttp/web_app.py”, line 310, in _handle
resp = await handler(request)
File “/usr/lib/python3.6/asyncio/coroutines.py”, line 213, in coro
res = yield from res
File “/usr/lib/python3.6/site-packages/appdaemon/rundash.py”, line 181, in call_service
data = yield from request.post()
TypeError: cannot ‘yield from’ a coroutine object in a non-coroutine generator
Hi have the same issue. Nothing works with 0.64.3 with AppDeamon 1.1.0.
Same issues here as well, .64.3 and AppDeamon 1.1.0, is there a way to revert to AppDeamon 1.0 to see if 1.1 is the issue?
I moved to AppDaemon 3.0 and now HADashboard is working correctly again.
I moved to AD 3.0 and is working fine as well. It seems that version 2.0 will not be fixed anymore.
@aimc Will check to see if the 2.x branch is easily fixable, if so, a minor release might be a possibility.
I’m traveling on business this week but I’ll take a look at the weekend
:warning: Important notice :warning:
AppDaemon2 has been deprecated for a while now and has been replaced by AppDaemon3.
This add-on will be removed from the Hassio Add-ons store within the next couple of days.
If you still haven’t upgraded, I’d strongly advise doing so.
Don’t worry, as long as the add-on is installed on your system; it will remain available to you. However, re-installing/downloading or newly installing the AppDaemon2 add-on will not possible.
:latin_cross: The add-on has been removed and is no longer available.
Thank you guys for the amazing ride and all your lovely comments :heart:
