can this be done via a HA command?
Community Hass.io Add-on: Google Assistant Webserver (broadcast messages without interrupting music)
Iām not sure what you mean by a HA command, but all you need to do is a simple HTTP POST (documented here: https://rithvikvibhu.github.io/GHLocalApi/#assistant-assistant-notifications-post
Iāve created a command line switch for all my assistant devices to control night mode and you should be able to do the same for DND.
Thanks for the link. Do you mind sharing your code for that? Command line switches are new to me.
- platform: command_line
switches:
dining_room_display_night_mode:
command_off: >
curl -H "Content-Type: application/json" -X POST -d '{"enabled":false}' http://<IP>:8008/setup/assistant/set_night_mode_params
command_on: >
curl -H "Content-Type: application/json" -X POST -d '{"do_not_disturb":false,"enabled":true,"led_brightness":0,"volume":0.5,"windows":[{"days":[0,1,2,3,4,5,6],"length_hours":24,"start_hour":0}]}' http://<IP>:8008/setup/assistant/set_night_mode_params
command_state: >
curl -X GET http://<IP>:8008/setup/eureka_info\?params\=night_mode_params
friendly_name: "Dining Room Display - Night Mode"
value_template: '{{ value_json.night_mode_params.enabled == true }}'
Thatās what I use for my night mode switches, youād have to adapt it for DND.
thanks for that
Tip
If you are using a BT Smarthub (UK) and you get the message displaying in My Activity" but no actual sound broadcast from your Google Home then try going into BT Smarthub advanced settings and then in the IPV6 options set IPv6 Address Allocation to Allocation Mode = āStatefulā.
Then reboot BT Smarthub and Google Home
I was finally able to install the addon on HassOS, now that I have configured it as instructed but for some reason the message does not seems to
http://hassio.local:5000/broadcast_message?message=testmessage
I only get the below response on my browser, any suggestions?
{āstatusā: āOKā}
I too tried this. In Google Myactivity it says your assistant needs permissions for that, maybe thereās a way to add those in Google console?
Supposedly Google Assistant SDK doesnāt allow playing/casting or even routines to kind of trigger those options.
Exactly wanted to do this. But seems like itās unsupported. Were you able to find a workaround for this?
My broadcasts have suddenly started to be proceeded by ābroadcast from name hereā then the intended message. Anyone know how to stop this as itās spoiling the experience.
You likely canāt. This is rolling out as part of the new intercom-ish broadcast features.
Came here to say this! This has ruined my broadcasting! It as if Google are trying to make thing difficult sometimes lol
No I wasnāt
Sorry
having the same issue
Bugger! This add on rules and this seriously compromises it. Someone do something smart!
Broadcasting/announcing the usual way āHey Google, Broadcast/announce messageā doesnāt append anything which is sort of promising that the prefix might be avoidable?
Since few days the broadcast is not working.
This is a complete guess, but Iām thinking the new behavior (āIncoming broadcast fromā¦ā) is added any time the broadcast is using the assistant voice rather than a recording of the person sending the broadcast. My guess is that this is designed so that if multiple people use the broadcast feature you can tell who it was from.
If I open assistant on my phone and type ābroadcast test messageā the broadcast comes out āBroadcast from Clayton: test messageā with the assistant voice (because I typed the message) however if I actually speak to an assistant speaker and tell it ābroadcast test messageā then the speakers broadcast only ātest messageā but in my recorded voice, so it doesnāt need to prepend āBroadcast from Claytonā.
If my guess is correct then I would assume thereās no way around it, unless Google adds an option in accessibility or something like that.
Youāre right I tried the same thing earlier. Although I can see the requirement for ānormalā use. For our use-case It really is a shame! Iāve come to use broadcast messages in a huge amount of automations and notifications. I really donāt want to go back to TTS and the plague of problems that had for me.
Hopefully Google do add an option or an adaptation of broadcasts for the specific purpose.
