When using console “hassio homeassistant check” in IDE, it takes a very long time before its done. Like 5minutes. When using hassios own check config features it only takes a couple of seconds before its done. Why is that?
Also in hassios “configurator”, there is a green or red marker on the upper right to instantly see if you have made something wrong in the configuration file. Is there any options for this in IDE? I cant find it.
Log
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] 10-hassio: applying...
[fix-attrs.d] 10-hassio: exited 0.
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Hass.io Add-on: IDE
Advanced IDE for Home Assistant, based on Cloud9 IDE
Add-on version: 2.1.1
You are running the latest version of this add-on.
System: Ubuntu 18.04.3 LTS (amd64 / intel-nuc)
Home Assistant version: 0.102.2
Supervisor version: 192
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] c9.sh: executing...
[cont-init.d] c9.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[16:39:11] INFO: Starting the C9...
Starting standalone
Connect server listening at http://127.0.0.1:80
CDN: version standalone initialized /cloud9/build
Started '/cloud9/configs/standalone' with config 'standalone'!
Cloud9 is up and running
[16:39:11] INFO: Starting Nginx...
nginx: [alert] detected a LuaJIT version which is not OpenResty's; many optimizations will be disabled and performance will be compromised (see https://github.com/openresty/luajit2 for OpenResty's LuaJIT or, even better, consider using the OpenResty releases from https://openresty.org/en/download.html)
2019/11/27 16:39:11 [emerg] 432#432: socket() [::]:8321 failed (97: Address family not supported by protocol)
nginx: [emerg] socket() [::]:8321 failed (97: Address family not supported by protocol)
[16:39:12] INFO: Starting Nginx...
2019/11/27 16:39:12 [emerg] 478#478: socket() [::]:8321 failed (97: Address family not supported by protocol)
[16:39:13] INFO: Starting Nginx...
Kind of a HASSIO newbie here. Just moved from Hassbian.
I am able to make this work locally, but when accessing remotely via my Nabucasa instance, it fails.
DO I need to open that 8321 port?
This add-on is powered by the Cloud9 IDE project, which has been acquired by
Amazon in 2016. As of 17 October 2018, the open source development of the
Cloud9 Core has been halted.
It became harder to maintain and keep this add-on running. As the world
advances, but the C9 does not, so things become incompatible over time.
The point of no longer being able to upgrade parts of the add-on, has come.
Therefore this add-on will no longer receive any updates and is deprecated.
If you are running Hass.io on an amd64 based system, we would recommend changing
to the vscode add-on. For other architectures (e.g., Raspberry Pi), we expect
to release an alternative add-on.
Is it still working?
I’m getting for some time already the following and it failed to start:
[fix-attrs.d] done.
Hass.io Add-on: IDE
Add-on version: 2.2.0
Home Assistant version: 0.104.3
Supervisor version: 195
[cont-init.d] done.
[services.d] done.
[12:34:03] INFO: Starting the C9...
Starting standalone
[12:34:03] INFO: Starting Nginx...
2020/02/03 12:34:03 [emerg] 435#435: socket() [::]:8321 failed (97: Address family not supported by protocol)
[12:34:04] INFO: Starting Nginx...
2020/02/03 12:34:04 [emerg] 481#481: socket() [::]:8321 failed (97: Address family not supported by protocol)
[12:34:05] INFO: Starting Nginx...
2020/02/03 12:34:05 [emerg] 499#499: socket() [::]:8321 failed (97: Address family not supported by protocol)
[12:34:06] INFO: Starting Nginx...
