Thank you!!! I was about to try my third attempt to get SSL working with NotoriousBDG’s addon, until I found your version. Just installed it, but so far so good–I’m able to see all my Home Assistant sensors and devices. I’ll buy you a coffee soon!
This is correct. The share folder is accessible by the add-on, but not used by the add-on.
E.g., if you have a camera posting images in the shares folder, you are now able to access the using your flows (or any other case).
The actual configuration / flows of Node-RED are stored in the /config/node-red/ folder.
I’m not sure what this has to do with the Node-RED add-on.
Actually, you do. Since the configuration is stored in /config/node-red you have several options getting access to them / backup them:
when adding “credential_secret” - is it supposed to disappear from the setting file after saving?
Have tried both using “credential_secret” and “credentialSecret” - added while the addon is stopped, saved after changing and then restartet the addon - and then the change dissapears…
Shouldn’t it stay there?
Thanks in advance,
Chr.
23 Jun 15:31:26 - [error] [server-state-changed:Security] TypeError: Cannot read property ‘state’ of null
on almost all my devices in node red. Automations seems to work. I have updated Hassio to 0.72 and that has started. Can I have any help please. BTW. I’m quite new to Hassio.
I need help repairing my node-red install. I started with Notorious-BDG version and add-on was working correctly. I then saw this released and wanted to use this one before I created any real flows. I uninstalled BDG version and added this. My mind draws a blank as to my next steps but lets just say I managed to mess up the HA integration (think I was trying to configure like BDG version - which wasn’t necessary).
I then decided to re-install the addon which didn’t help. Reading a previous post, I uninstalled the addon, deleted the node-red folders from share and config (hadn’t removed BDG folder), which seems to have removed the files but there’s a couple of empty folders that won’t delete, rebooted rpi3, and tried installing addon again. I have a credential_secret, user and SSL configured.
Now I get the following from the log window of the addon:
It seems to not have replaced the folder contents with fresh files as config/node-red still has a few empty sub-folders.
How do I clear out the addon completely so I can start fresh?
secondary question: once running, how do I get rid of the annoying git project message… I don’t want to store any files publicly in git or set up my own git server thanks. Happy as long as my flows are saved as part of a hassio snapshot.
Thanks @frenck for the steer along the right lines. The stubborn empty folder structure was causing the issue. I had to SSH into the Pi then use the following to delete the folders:
cd /share [edit: meant cd /config]
rm -r node-red
Starting the web UI, it wouldn’t accept my username/PW until I restarted HA.
Do you have a solution for the project pop-up screen? Is there a way to add a “don’t ask me again unless I click an option in the settings”?
That is odd, since this add-on does not use that folder. There are a couple of other node-red add-ons out there that do, so maybe you are in the wrong topic.
I’m getting an error message when I start the add-on after configuring the settings as specified in the github install instructions and hitting save. The error message in the add-on log is, "Error: Cannot find module ‘bcryptjs’. I’ve tried installing bcryptjs via the “npm_packages” and “system_packages” configuration parameters, but haven’t been successful with a variety of package names. I’m running the latest version of hassio. Will someone please let me know how to properly install the ‘bcryptjs’ module?
In some of the other add ons of Node Red there is a timestamp node which makes it possible to trigger the flow manually when testing. That is missing here, but is there another node that does the same?
I also see this same problem. Projects were added in 0.18 and it uses git, with optional remotes, for version control built directly into node-red.
It would use SSH keys from here: /config/node-red/projects/.sshkeys/
But as mentioned it cannot generate them - probably as ssh-keygen is not in this container.
Also when you try to connect to the git remote from the history tab it cannot - probably no git.
