Thanks. I am running pai in a docker container. Portainer’s log shows this:
2020-09-23 07:09:07,492 - INFO - PAI.paradox.paradox - Initiating panel connection
2020-09-23 07:09:07,600 - INFO - PAI.paradox.hardware.spectra_magellan.panel - Installer login
2020-09-23 07:09:07,701 - INFO - PAI.paradox.hardware.spectra_magellan.panel - Authentication Success
2020-09-23 07:09:07,702 - INFO - PAI.paradox.paradox - Connection OK
2020-09-23 07:09:07,703 - INFO - PAI.paradox.paradox - Loading data from panel memory
2020-09-23 07:09:07,704 - INFO - PAI.paradox.hardware.panel - Loading definitions
2020-09-23 07:09:07,704 - INFO - PAI.paradox.hardware.panel - Updating Definitions from Panel
2020-09-23 07:09:08,202 - INFO - PAI.paradox.interfaces.mqtt.core - MQTT Broker Connected
2020-09-23 07:09:08,411 - INFO - PAI.paradox.hardware.panel - Zone definitions loaded (0.71s)
2020-09-23 07:09:08,421 - INFO - PAI.paradox.hardware.panel - Loading labels
2020-09-23 07:09:08,422 - INFO - PAI.paradox.hardware.panel - Updating Labels from Panel
2020-09-23 07:09:08,893 - INFO - PAI.paradox.hardware.panel - Zone labels loaded (0.47s): Garage_RS, Garage_PIR, Front_Door_PIR, Lounge_PIR, Living_Room_PIR, Corridor_PIR, Laundry_PIR, Tamper, Front_Door_RS, Shopper Door
2020-09-23 07:09:09,646 - INFO - PAI.paradox.hardware.panel - Pgm labels loaded (0.75s): External Strobe, Internal Siren, PGM3, PGM4, PGM5, Output 06, Output 07, Output 08, Output 09, Output 10, Output 11, Output 12, RTX3 PGM1, RTX3 PGM2, RTX3 PGM3, RTX3 PGM3
2020-09-23 07:09:09,740 - INFO - PAI.paradox.hardware.panel - Partition labels loaded (0.09s): Garage, House
2020-09-23 07:09:11,275 - INFO - PAI.paradox.hardware.panel - User labels loaded (1.54s): System Master, , , Joseph, Norah, User 06, User 07, User 08, User 09, User 10, User 11, User 12, User 13, User 14, User 15, User 16, User 17, User 18, User 19, User 20, User 21, User 22, User 23, User 24, User 25, User 26, User 27, User 28, User 29, User 30, User 31, User 32
2020-09-23 07:09:12,062 - INFO - PAI.paradox.hardware.panel - Module labels loaded (0.79s): Bus Module 01, Bus Module 02, Bus Module 03, Bus Module 04, Bus Module 05, Bus Module 06, Bus Module 07, Bus Module 08, Bus Module 09, Bus Module 10, Bus Module 11, Bus Module 12, Bus Module 13, Bus Module 14, Bus Module 15
2020-09-23 07:09:12,155 - INFO - PAI.paradox.hardware.panel - Repeater labels loaded (0.09s): Repeater 1, Repeater 2
2020-09-23 07:09:12,532 - INFO - PAI.paradox.hardware.panel - Keypad labels loaded (0.38s): Wireless Keyp 1, Wireless Keyp 2, Wireless Keyp 3, Wireless Keyp 4, Wireless Keyp 5, Wireless Keyp 6, Wireless Keyp 7, Wireless Keyp 8
2020-09-23 07:09:12,626 - INFO - PAI.paradox.hardware.panel - Site labels loaded (0.09s): Your Alarm Site
2020-09-23 07:09:12,814 - INFO - PAI.paradox.hardware.panel - Siren labels loaded (0.19s): Wireless Siren 1, Wireless Siren 2, Wireless Siren 3
2020-09-23 07:09:12,815 - INFO - PAI.paradox.paradox - Running
I gather that this means PAI is running?
But the paradox.log in /var/log shows this:
2020-09-23 07:11:55,227 - ERROR - PAI.paradox.connections.protocols - Connection was closed: None
2020-09-23 07:11:55,227 - ERROR - PAI.paradox.connections.connection - Connection was lost
Something is not right.
What should I change please?
edit: after I restart pai, the MQTT seem to be a problem.
> 2020-09-23 07:16:12,898 - WARNING - PAI.paradox.interfaces.mqtt.core - Connection failed, retrying: Address in use(98)
> 2020-09-23 07:16:13,009 - INFO - PAI.paradox.hardware.panel - Zone definitions loaded (0.66s)
> 2020-09-23 07:16:13,016 - INFO - PAI.paradox.hardware.panel - Loading labels
> 2020-09-23 07:16:13,017 - INFO - PAI.paradox.hardware.panel - Updating Labels from Panel
> 2020-09-23 07:16:13,517 - INFO - PAI.paradox.hardware.panel - Zone labels loaded (0.5s): Garage_RS, Garage_PIR, Front_Door_PIR, Lounge_PIR, Living_Room_PIR, Corridor_PIR, Laundry_PIR, Tamper, Front_Door_RS, Shopper Door
> 2020-09-23 07:16:14,269 - INFO - PAI.paradox.hardware.panel - Pgm labels loaded (0.75s): External Strobe, Internal Siren, PGM3, PGM4, PGM5, Output 06, Output 07, Output 08, Output 09, Output 10, Output 11, Output 12, RTX3 PGM1, RTX3 PGM2, RTX3 PGM3, RTX3 PGM3
> 2020-09-23 07:16:14,365 - INFO - PAI.paradox.hardware.panel - Partition labels loaded (0.1s): Garage, House
> 2020-09-23 07:16:14,900 - WARNING - PAI.paradox.interfaces.mqtt.core - Connection failed, retrying: Address in use(98)
> 2020-09-23 07:16:15,902 - INFO - PAI.paradox.hardware.panel - User labels loaded (1.54s): System Master, , , Joseph, Norah, User 06, User 07, User 08, User 09, User 10, User 11, User 12, User 13, User 14, User 15, User 16, User 17, User 18, User 19, User 20, User 21, User 22, User 23, User 24, User 25, User 26, User 27, User 28, User 29, User 30, User 31, User 32
> 2020-09-23 07:16:16,655 - INFO - PAI.paradox.hardware.panel - Module labels loaded (0.75s): Bus Module 01, Bus Module 02, Bus Module 03, Bus Module 04, Bus Module 05, Bus Module 06, Bus Module 07, Bus Module 08, Bus Module 09, Bus Module 10, Bus Module 11, Bus Module 12, Bus Module 13, Bus Module 14, Bus Module 15
> 2020-09-23 07:16:16,749 - INFO - PAI.paradox.hardware.panel - Repeater labels loaded (0.09s): Repeater 1, Repeater 2
> 2020-09-23 07:16:17,124 - INFO - PAI.paradox.hardware.panel - Keypad labels loaded (0.38s): Wireless Keyp 1, Wireless Keyp 2, Wireless Keyp 3, Wireless Keyp 4, Wireless Keyp 5, Wireless Keyp 6, Wireless Keyp 7, Wireless Keyp 8
> 2020-09-23 07:16:17,220 - INFO - PAI.paradox.hardware.panel - Site labels loaded (0.1s): Your Alarm Site
> 2020-09-23 07:16:17,440 - INFO - PAI.paradox.hardware.panel - Siren labels loaded (0.22s): Wireless Siren 1, Wireless Siren 2, Wireless Siren 3
> 2020-09-23 07:16:17,441 - INFO - PAI.paradox.paradox - Running
> 2020-09-23 07:16:18,901 - WARNING - PAI.paradox.interfaces.mqtt.core - Connection failed, retrying: Address in use(98)
> 2020-09-23 07:16:26,903 - WARNING - PAI.paradox.interfaces.mqtt.core - Connection failed, retrying: Address in use(98)
> 2020-09-23 07:16:42,905 - WARNING - PAI.paradox.interfaces.mqtt.core - Connection failed, retrying: Address in use(98)
> 2020-09-23 07:17:14,908 - INFO - PAI.paradox.interfaces.mqtt.core - MQTT Broker Connected
