Home Assistant Community Add-on: TasmoAdmin
any idea why auto scan won’t find anything for me if i add manually finds instantly and i’m good but no matter how many times i try to reinstall never works
thanks for your time
New install, HASS.io with this addon but it will not run… here is log…
Log
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] 01-tasmoadmin: applying…
[fix-attrs.d] 01-tasmoadmin: exited 0.
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] 00-banner.sh: executing…
Hass.io Add-on: TasmoAdmin v0.6.0
Centrally manage all your Sonoff-Tasmota devices
By: Franck Nijhof [email protected]
armhf / HassOS 1.12 / HA 0.82.1 / SU 139 / stable
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing…
Log level is set to INFO
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] 02-updates.sh: executing…
INFO: You are running the latest version of this add-on
[cont-init.d] 02-updates.sh: exited 0.
[cont-init.d] 10-requirements.sh: executing…
FATAL: The configured certfile is not found
[cont-init.d] 10-requirements.sh: exited 1.
[cont-finish.d] executing container finish scripts…
[cont-finish.d] 99-message.sh: executing…
            Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] syncing disks.
[s6-finish] sending all processes the TERM signal.
any ideas???
Thx…
Here is an idea, which you posted yourself when copying over the log:
Bonus tip: lines explaining what went wrong start with ‘FATAL’.
This is the problem. It looks like you probably have SSL enabled, but do not have certificates.
If you intended to use SSL, you don’t have it set up right, or you do not have the “certfile” or “keyfile” parameters set right in the add-on config.
If you are not using SSL, make sure you have it disabled in the add-on config, the line for that should look like this; make sure it’s set to false to disable SSL.
“ssl”: false,
I have problem with opening TasmoAdmin via ifpanel from outside my local network. It shows that connection is refused.
I am connecting through DuckDNS with SSL enabled. Is it possible to configure TasmoAdmin so I can log into panel from outside network or it works only in local network?
I have my iframe pointing to my duckdns address and it works inside and outside. What is your iFrame setup? You have to choose between http and https and it needs to match how you access home assistant itself as well.
It seems that port in http: section was a culprit. After removing “:8123” from base_url, TasmoAdmin iFrame started to work. At least on my mobile phone (dissconected from wifi). Tomorrow I will test from my office.
Thank you!
Hi everyone,
I am new to all this; installed recently HASSIO and added TasmoAdmin and getting a problem loading it
What directory/file should I disable to ssl certificate?
Thanks in advance
:tada: Release v0.6.1
Full Changelog
Changed
  • Upgrades git to 2.18.1-r0
  • Removes BountySource links
  • Fixes spelling error in Dockerfile
  • Upgrades nginx to 1.14.2-r0
  • Removes Anchore.io links
  • Updates maintenance year to 2019
  • Upgrades add-on base image to 2.3.1
  • Upgrades PHP to 7.2.13-r0
  • Configure Renovate (#35)
  • Replaces add-on link with GitHub link
Questions? Join our Discord server! https://discord.me/hassioaddons
Enjoying my add-ons? Consider supporting my work: https://patreon.com/frenck
any chance of getting this for non-hassio installs? :frowning:
Just use one of the other install methods for TasmoAdmin. This add-on is a wrapper for easy installation on Hass.io only.
Hi everybody,
I cannot start the add-on on hassio 0.89. The add-on is installed, but it does not start and there is no log reported. I am not using ssl, therefore this is my configuration:
  "log_level": "info",
  "ssl": false,
  "certfile": "fullchain.pem",
  "keyfile": "privkey.pem",
  "ipv6": false
this is all I get in home assistant logs:
19-03-29 22:49:01 INFO (SyncWorker_13) [hassio.docker.interface] Clean hassioaddons/sonweb-aarch64 Docker application
19-03-29 22:49:04 INFO (SyncWorker_13) [hassio.docker.addon] Start Docker add-on hassioaddons/sonweb-aarch64 with version v0.6.1
Thanks to anybody willing to help!
:tada: Release v0.7.0
Full Changelog
Changed
  • :arrow_up: Upgrades add-on base image to 3.0.1
  • :sparkles: Adds ARMv7 support
  • :arrow_up: Upgrades PHP to 7.2.14-r0
  • :arrow_up: Upgrades git to 2.20.1-r0
  • :arrow_up: Upgrades TasmoAdmin to v1.6.1-beta1
  • :hammer: Makes log_level optional
  • :fire: Removes IPv6 switch
  • :fire: Removes custom log format override
  • :hammer: Rewrite add-on onto Bashio
  • :hammer: Makes NGinx wait for PHP-FPM before starting
  • :hammer: Output proper info messages when services start
  • :ambulance: Fixes incorrect timeout command call
Same here…
:tada: Release v0.7.1
Full Changelog
This is a general maintenance release, without any breaking changes.
:hammer: Changes
  • :arrow_up: Upgrades base image to v3.1.0
  • :arrow_up: Upgrades PHP to 7.2.17-r0
  • :sparkles: Adds port descriptions
  • :hammer: Refactor of init scripts
0.6.0
0.7.0
0.4.1 What???
My bad will correct that asap
Corrected
Will you allow a logged in HA user to bypass user/pass?
This addon does not support ingress, so no
Will it support Ingress?
