Are you sure SSL is installed and working? What address do you use to go into Home Assistant? Is it a LetsEncrypt certificate or self signed?
Sorry, SSL is not installed, I was thinking of ssh, which is installed.
Thanks for bringing this up, I kept reading ssh instead of SSL
And, I did not install LetsEncrypt.
I guess you just solved all my issues.
A huge "thank you!"
Release v2.4.0
This release is exciting, at least, for me it is. Iāve been working on this for months! And for you? Well, almost nothing changed
So what did change? Iāve updated the workflows of the Community Hass.io Add-ons project. Things include:
- Replaced CircleCI and CodeClimate. We are now using GitLab CI, backed by a couple of custom servers building and testing these add-ons.
- All add-ons are now scanned during built and release by Clair to prevent security issues in our add-ons.
- All add-ons are constantly scanned and monitored by Anchore.io. We will be notified immediately in case of security issues occur. (Major thanks to Anchore.io for helping us out!)
- The add-ons repository is now entirely generated and automatically synced with all the add-ons. This ensures repositories are in sync, never forgotten and releases are almost instantly.
- The base images that these add-ons are built on are entirely revised.
- All add-ons have been updated to follow the Docker best practices. These are checked on every code change by GitLab CI.
- All add-ons had maintenance. All software is updated to the latest and greatest and the documentation has been revisited.
- There are now 2 bots in place on the GitHub project. The Add-ons Assistant is helping us out with the GitHub issues and pull requests and the AddonsBot is fully active taking care of updating code across the different GitHub Repositories.
- We now have Edge & Beta add-ons repositories available. This allows everybody to test the latest and greatest (in case you donāt care about stability that much, or just wanna help out!)
- Iāve removed all the PayPal, Bitcoin, ā¦ buttons. If youād like to show your appreciation, then please, just buy me a coffee.
So thatās quite a lot, right? So what changed in this specific add-on?
Added
- Adds SQLite by default
- Adds .yamllint configuration
- Adds all architectures to add-on config
- Adds Probot configuration
- Adds initial add-on README template
- Adds Gitlab CI
Fixed
- Fixes Markdownlint warning in License
Changed
- Replaces Changelog with GitHub releases
- Updates hassio-cli to v1.3.0 (#22) (@bastula)
- Updates README
- Upgrades add-on base image to v1.4.1
- Downgrades ttyd to 1.3.3-r3
Removed
- Removes CircleCI
- Removes CodeClimate
- Removes supervisor version constraint from add-on config
only seeing 2.3 hereā¦
Go to the add-on store and hit the refresh button in the top rightā¦
Bugger!!! I reloaded the supervisor before posting. Found it now. Thanks.
Release v2.4.1
Changed
- Updates hassio-cli to v1.3.1
- Updates bind-tools to 9.11.3-r0
- Updates sqlite to 3.21.0-r1
Release v2.5.0
Changed
- Moves build-env to latest
- Upgrades base image to v1.4.2
- Upgrades git to 2.15.2-r0
- Rewrites GitLab CI
Hi Guys!
Iām considering merging this add-on (Terminal add-on) with the SSH add-on.
The advantages of this would be:
- Pick up sessions from SSH using your web terminal
- Pick up session from your Web terminal using SSH
- Smaller footprint (in case you have both installed)
- Less maintenance for me
What do you think?
as long as they have the same functionality should be ok. However until this week I was running the official ssh addon and Terminalā¦ you will be forcing people who only want one to use both.
That is something I could solve, by adding an option to enable/disable SSH and/or the Terminal.
E.g., "ssh": false
and "terminal": true
Release v2.5.1
Deprecation warning
This add-on is in a deprecated state!
This add-on is now deprecated and has been replaced by a different addon:
āSSH & Web Terminalā
This new add-on combines the SSH and Terminal add-ons into one single powerful
solution, contains the latest upgrades and updates, and provide much more tools.
Please upgrade asap since this add-on wonāt receive any updates or upgrades
anymore.
Changed
- Deprecates the add-on
The add-on has now been removed from the repository and the add-on store.
See message above for the alternative.
