Community Highlights: 7th edition
The 7th edition of the Home Assistant Community Highlights! Some interesting things popped up around our community, we thought was worth sharing.
Troy Hunt has jumped into our wonderful world and shared his journey in a blog post series. Some nice examples on a DIY solution for mounting a wall tablet and how to arm your alarm with a toothbrush!
Troy Hunt is unraveling IoT using Home Assistant
If you have never heard of Troy Hunt before, he is a web security specialist and mostly known for creating “Have I Been Pwned” (Home Assistant integration).
Troy has been diving into the world of IoT and started automating his home, using… Home Assistant!
I'm massively impressed with HA and nothing else I've seen along my IoT journey comes even close to comparing. If you're going to do IoT in any meaningful way, you start with HA.
Troy Hunt
In 5 blogs, he writes about his journey in the big world of IoT:
The 5th part Troy made 11! short and quick videos, showing actual use cases in his home. Really cool and inspiring!
Framing a wall-mounted tablet
If you are a bit like me, you probably want to wall mount a tablet someday (or you already have it of course 🥴). Doing that in a nice, elegant and pretty way is often the hard part. Especially if you only have brick walls (like me), which makes it hard to hide cable or recess the tablet.
Next I came across 2 posts on on the Home Assistant subreddit, which, if you haven’t done already, should totally join.
This one popped up, made by ialex87, which uses a 3D printed frame from Thingiverse to which he glued a wooden frame to make it look like a photo frame.
Nothing much, but my honest work! from r/homeassistant
Next, Invinciberry shared his version:
Now let's wall mount this thing. from r/homeassistant
Both look very slick! Thanks for sharing!
Arm your alarm by brushing your teeth…
Automatically arm your alarm, when Home Assistant detects you are using your toothbrush… Why? Because we can! 😎
Have you ever seen a house alarm system controlled by a toothbrush? Here our @VanderbiltInd alarm is integrated into @home_assistant . Our toothbrush is ble enabled, it’s state is read by an ESP32 chip and sent into @home_assistant pic.twitter.com/T9XGi1Zjmb
— Ian (@imduffy15) November 19, 2020
Home Assistant Conference
This isn’t a highlight yet, but without a doubt, it is definitely is going to become one of the highlights of this year: The Home Assistant Conference.
Sunday, 13 December, we’ll be looking back at last year; but more importantly, lots of great talks are planned by speakers from our community about all different kinds of subjects:
Above all, some new and exciting stuff is going to be announced as well! So, ensure you don’t miss it.
Get your $1 ticket
Or, check the Home Assistant Conference page for other ways on how to watch.
Got a tip for the next edition?
Have you seen (or made) something awesome, interesting, unique, amazing, inspirational, unusual or funny, using Home Assistant?
Click here to send us your Community Highlight suggestion.
Also, don’t forget to share your creations with us via Social Media:
See you next edition!
This is a companion discussion topic for the original entry at https://www.home-assistant.io/blog/2020/12/01/community-highlights/
Probably not the best place to show off with my solution, but it may help and inspire people.
Basically cut a QI wireless charger receiver and use the tiny connector with the ribbon cable to it.
Cool solution.
I found this usb cable: Slim Power Cable - Male USB-A to 90 Degree Male USB-C – Smart Home Mount
These usb cables look good https://www.aliexpress.com/item/32866540017.html
Unfortunately not. The cable needs to bend 180 degrees right after the connector, so the cable can go behind the device. This one has 90 degree connector PCB, that is too big and will prevent mounting directly to the wall.
mbmounts.com is a super popular solution in the ST world (recently defected).
I have a his mounts and they work great. He has solutions for almost every tablet with almost every combination of power needs.
