Home Assistant land has been busy and a lot of people have been creating awesome stuff. We’ve added a cookbook section to the website full of examples how you can automate different things. Make sure you take a look and share your own recipes too!
Home automation demo by Part of the Thing
Haaska - Alexa Skill Adapter for Home Assistant
Haaska allows you to control lights, switches, and scenes exposed by your Home Assistant instance using an Amazon Echo. This is different from our own Alexa component because it will teach the Amazon Echo directly about the devices instead of teaching it to talk to Home Assistant. It will not allow you to use custom sentences but it will allow you to skip the ‘Ask Home Assistant’ part when giving commands:
- “Alexa, set kitchen to twenty percent”
- “Alexa, turn on evening scene”
- “Alexa, turn off bedroom light”
Integrating Home Assistant with HomeKit
Contributor Maddox has created a plugin for HomeBridge, an open-source HomeKit bridge. This will allow you to control your home using Siri on your Apple devices. HomeBridge has recently restructured so you’ll have to install the plugin separately with the homebridge-homeassistant npm package.
Example config.json entry to load Home Assistant:
"platforms": [
"platform": "HomeAssistant",
"name": "HomeAssistant",
"host": "http://192.168.1.50:8123",
"password": "xxx",
"supported_types": ["light", "switch", "media_player", "scene"]
HomeBridge on GitHub HomeBridge Home Assistant Plugin
Custom alarm system with Home Assistant
User thaijames describes in the Home Assistant forums how he has created his own NFC-based alarm system using Home Assistant, DIY components and Garfield dolls.
 Hold your NFC tag against the belly of Garfield to unlock the alarm.
This is a companion discussion topic for the original entry at https://home-assistant.io/blog/2016/02/20/community-highlights/
