I’m in the process migrating from Domoticz to Home Assistant and still figuring things out. One thing I can’t find any solution for is the placement of the notification dot when using CCH:
mayker
(maykar (pronounced "maker" with a southern accent))
1327
CCH is being replaced soon with a completely new project. CCH has many issues and small changes in HA can cause big issues in multiple places in CCH (not HA’s fault ).
The new project aims to fix these issues, make it much easier to fix things when something in HA changes, add many new features not possible with how CCH currently works, and much more.
I apologize that I cannot give as much time to fixing and troubleshooting CCH at the moment, but be assured it’s for the best. That being said, please be patient while it is being worked on and to put a band-aid on the recent issues on this thread:
@klogg For the moment it’s best not to use the voice icon as a clock or in overflow. I put some duct tape on an issue caused by the voice element changing, but can’t really get into a complete fix.
@Zucht Try adding notify_indicator_color: transparent to hide the notification dot for the time being.
not sure if this has to do with the update, but since that, I cant get the right chevron to work. Clicking it does nothing. Manually swiping to the right, makes the right chevron disappear, which should happen of course, but then the most right tab/icon is dead…
HA 101.3, CCH 1.4.9
Hi folks. Long-time listener, first-time caller here… Please forgive me if this has already been asked, but I have an issue that I haven’t seen called out in any of the searches I’ve done.
I have a custom view defined for mobile devices. When accessing via a mobile device, I have CCH configured to hide the home tab (#0) and display my mobile view as the default instead. This all seems to work fine until I navigate somewhere else (map, logbook, etc.) and come back (via the Overview button). In those cases, I land back on the (hidden) Home tab.
Has anyone else run into this? Am I just doing something wrong? Or is this to be expected?
Have you set the default_tab?
Cause I cannot simulate you issue with follwoing setup. No CCM for PC and different layouts for mobile and tablet (home dashboard)
@mayker First off…thanks for making this awesome customization. I’m fairly new to Hassio and it was the little projects like yours that helped convince me to jump ship.
I upgraded to 102 today. My header has returned (it does minimize when I scroll down)
and I’m getting this error in the log every time I refresh lovelace. Cannot read property 'querySelector' of null 2:02 PM components/system_log/__init__.py
I reached out to a friend who also uses CCHeader and he is experiencing the same. Thoughts?
Updated to 1.4.9. …Issue persisted. Reinstalled 1.4.9… same.
Then sat at my desktop and did a ctrl+F5 to force complete refresh and it works fine on my desktop. I still have the issue on my HA android app and android chrome. Now to figure out how to force a refresh on those interfaces.
Edit:
Cleared the HA and Chrome app cache on android and we’re good to go
Not sure if the plugin version, the clearing of the app cache or a combination of both fixed it.
Thanks for the responses.
