Home Assistant Community
Compact Custom Header
#289
Not sure why on the first card, it shows the compact-custom-header at top and bottom of first column… and if I click on edit for the second one, it opens up the GUI editor for the card?
actually I do know why… somehow I had it on that column at the top and the bottom. All good!
Must have crept in with the raw editor
#290
@mayker great job, card works great!!!
just one question is there any tracker.json url for we be able to use with tracker card, custom updater?
#291
He specifically said it has been removed TEMPORARILY from the custom tracker - presumably because of the major breaking changes.
#292
ty @DavidFW1960 missed that part…
#293
David is correct, the card was removed temporarily. Also, a tracker.json file & URL is not needed for this project as it is included in custom-updater by default. Expect it to be back up there next week.
Do I understand it correctly if I think I have to have - type: custom:compact-custom-header in every view, but only do the config in the view where I set the main_config option to true, when I’m in yaml mode?
#295
Yes, you are correct! :slight_smile:
This is great i downloaded the new version and done the config and it works really well .
Thank you @mayker @Bram_Kragten :smiley::smiley:
#297
I never was able to use the per user tab settings…
Now with latest version, gave it a try again… still can’t hide the tabs for my GF username… (I cleared cache, rebooted, etc…)
  - title: Home
    icon: mdi:home-assistant
    # badges:
      # - binary_sensor.presence_josee_lg
    cards:
        main_config: true
        menu: show
        options: show
        voice: hide
        clock_format: 12
        exceptions:
          - conditions:
              user: jsimard
              menu: hide
            config:
              hide_tabs: 2,3,4,5,6,7,8,9,10,11,12,13
And I added the - type: custom:compact-custom-header in each view…
Anything I’m doing wrong?
#298
Take menu: hide out of conditions, it belongs in config:
    main_config: true
    menu: show
    options: show
    voice: hide
    clock_format: 12
    exceptions:
      - conditions:
          user: jsimard
        config:
          menu: hide
Give that a try
#299
Tried (and cleared cache, etc…), same issue, user sees all tabs and menu…
  - title: Home
    # badges:
    cards:
        main_config: true
        menu: show
        options: show
        voice: hide
        clock_format: 12
        exceptions:
          - conditions:
              user: jsimard
            config:
              menu: hide
I know it loads since the header is compacted…
#300
You’re absolutely sure that the username is correct, the user is logged in, and there are no special characters in the name?
#301
That’s what I wasn’t 100% sure…
I log in really typing in the username “jsimard” so must be it…
in the user settings, it only shows the full name and ID…
#302
Her full name contains an accent though (not the username)
2019-02-11%2011_56_42-Home%20Assistant
#303
open the sidebar menu and click the circle icon like the top right of this image:
It should say “You are currently logged in as” followed by the username
#304
OHHHH… so the “username” is really the full name? (because I login as “jsimard” but it shows the full name in “you are logged in as”
Just tried the full name with double quotes and it works… confusing lol…
  - title: Home
    # badges:
    cards:
        main_config: true
        menu: show
        options: show
        voice: hide
        clock_format: 12
        exceptions:
          - conditions:
              user: 'Josée Simard'
            config:
              menu: hide
              hide_tabs: 1,2,3,4,5,6,7,8,9,10,11,12
#305
I only use usernames for my user’s, but I guess if you assign them full names then that’s what hass reports. Glad we figured it out.
Questions, is it possible to disable the “compact header” part without disabling everything else?
I basically just need to disable menu and tabs for some specific users but still want the standard header size…
#307
Not currently, you should add it to the feature requests on the github.
Unfortunately, I got:
SyntaxError: dynamic module import is not implemented [compact-custom-header.js:51:64](http://hassio.local:8123/local/custom-lovelace/compact-custom-header/compact-custom-header.js?v=0.0.1)
in a Firefox (ver. 65) console. In Chrome everything works OK.
