Compact Custom Header
Thanks @mayker, the customizing options are awesome. :clap:
Looks like there’s a problem with views panel: true
Reloading them (CTRL-F5) shows the full header.
Auswahl_185
Switching from a normal view, the cards are under the header.
Auswahl_186
No errors in HA log or the console.
Thank you. Found the issue. Working on a fix now.
Just released 1.0.1b8 to fix panel view.
Thanks, that was indeed what i was meaning, to theme the style by user/device just like i can hide things by user/device :slight_smile: Great work!
Thanks for this update. Thought about requesting a theming option, but you make wishes come true before I even tell them :smiley:
Makes my theme look way better!
I don’t seem to be able to hide the am/pm indicator on the clock?
      - type: custom:compact-custom-header
        main_config: true
        menu: hide
        options: clock
        voice: overflow
        notifications: overflow
        header: true
        clock_format: 24
        clock_am_pm: false
Even if I keep it to 12hr format I still see it
The indicator has in the last day moved to a second line:
Any errors in HA or in your browsers dev-tools (F12)?
What version of HA and what browser are you using?
Have you tried a hard refresh?
No errors that I can see.
Seems it was a caching issue though, few browser restarts and it works as expected. Apologies
Small update to add custom color for current/active tab’s icon. 1.0.1b9
active_tab_color:
Update
1.0.2b0
This update adds the ability to use your HA theme to style CCH. This will make it so that when sharing a theme to the community you’ll be able to include CCH styling easily. This will also lighten your lovelace config a bit. Values set in config will override ones set in the theme. The only styles not available while doing this are individual tab colors. Check the end of the github readme for more.
If no background_color is configured, the default is transparent?
No sorry, I should have been more apparent. Those values are just examples. Will add that to the readme. Default is just HA’s default colors, etc.
Sorry, should be more precise.
I have no CCH variables in my theme and all i have in LL config is:
  menu: overflow
  exceptions:
But the header is transparent.
Auswahl_021
Ah okay, will look into it.
Fixed in 1.0.2b1, thank you!
Updated to .90 a bit ago. I was a few versions behind on CCH. Took me a bit of cache clearing, but finally got it working. but I seem to be having this error now. Everything loaded under the tabs
Are you using the latest version of the card? Do any errors display in HA log or in your browsers Dev-Tools (F12)? Is this only happening on views with panel: true?
This is my config. I have not changed it in quite a while since it has just worked
clock_am_pm: true
clock_format: '12'
disable: false
exceptions:
  - conditions:
      user: Paul
    config:
      show_tabs: '0,1,2,3,4'
      voice: show
  - conditions:
      user: Tracy
    config:
      show_tabs: '0,1,2,3'
header: true
main_config: true
menu: hide
options: show
show_tabs: null
type: 'custom:compact-custom-header'
voice: hide
I did not have panel: listed at all. I tried it as true and false, and it did not seem to make a difference, Im having the issue in chrome and in the iOS app.
Maybe it’s because I have not added the CCH to my other tabs?
Most likely. That is a requirement.
