Looks like my version got updated to the none legacy one, thanks for the confirmation and maintaining it @pjv really appreciate it! All working now
Total awesomeness Congrats!!!
Wow well done on the latest update.
Can’t wait to try it.
Nice work!
First off, I’ve done a hard reload. (F12, Empty cache and hard reload)
I’m not getting any styling applied to my notifications indicator and also this error…
My config is:
- type: custom:compact-custom-header
main_config: true
background_color: var(--primary-background-color)
active_tab_color: yellow
tab_indicator_color: yellow
notify_indicator_color: yellow
notify_text_color: black
menu: show
notifications: show
voice: clock
options: show
clock_format: 24
clock_date: true
date_locale: en-gb
exceptions:
- conditions:
user_agent: Mobile
config:
notifications: show
voice: hide
conditional_styles:
- entity: notifications
condition:
state: false
button:
notifications:
hide: true
Any ideas?
Thanks.
Thanks for finding that one. Just released a fix.
Is there any reason why this has broken on my Amazon Fire tablet?
It was previously working fine until i updated to the last HA and the latest update for this card.
I know the android webview doesnt support some custom cards but as i mentioned, it was previously working but now with the latest updates it is not.
Edit: It works fine on my iOS and Windows devices.
Ahhhh this makes sense. The first sentence says it all… changing from type: js to module.
Might have to look into @pjv of compiling an older version until Amazon pull their finger out.
Thanks. Notifications are now being hidden but the notify_indicator_color
styling isn’t being applied when they do appear (it used to work, one or two versions ago). I can get notify_text_color
to change.
main_config: true
notify_indicator_color: yellow # <----
menu: show
notifications: show
voice: clock
options: show
clock_format: 24
clock_date: true
date_locale: en-gb
exceptions:
- conditions:
user_agent: Mobile
config:
notifications: show
voice: hide
conditional_styles:
condition:
state: false
button:
notifications:
hide: true
Thanks again, fixed in latest.
Since updating to 0.91, CCH doesn’t seem to be working properly for me anymore.
I’ve got icons without text for my tabs, like I should, but the hamburger menu, notification icons, and title, etc. are showing up now.
Any errors in the HA logs or in your browser’s Dev-Tools (F12) pertaining to CCH? What does your config for CCH look like? What does your resources section for CCH look like?
Does anyone know how to set the background_image
to the right? I have tried adding right
before the url and also tried background-location but neither seem to work?
The only way I know is to create an image(.png works for me) around 50px in height by your screen resolution you are viewing on, ex. 1920px, and then add the image where you want it displayed in the header. Save that image and then use that for CCH background image.
@Dino-Tech thanks, it is a shame we can use standard CSS types in the same way the Themes function uses them for a background image. The only issue with what you propose is that there would need to be a different image for each form factor you wanted to present on and also within that form factor the image will move based on if the side menu is open or not
Yeah, Iknow. Probably a better way, but since I don’t use tabs in my headers it works fine for my set up.
Please, don’t hesitate to add feature requests on the github.
Thank you for adding the feature request for me, in future I will be sure to do so
Here is my Lovelace config:
resources:
- type: module
url: >-
/local/custom-lovelace/compact-custom-header/compact-custom-header.js?v=0.0.1
title: Dashboard
- badges: []
cards:
- cards:
- clock_format: '12'
menu: overflow
notifications: hide
options: clock
type: 'custom:compact-custom-header'
voice: overflow
And I found this error in Chrome’s dev tools:
Can’t find ‘hui-root’, going to walk the DOM to find it.
compact-custom-header.js?v=0.0.1:195 Uncaught (in promise) TypeError: Cannot read property ‘querySelector’ of undefined
at HTMLElement.run (compact-custom-header.js?v=0.0.1:195)
at HTMLElement.buildConfig (compact-custom-header.js?v=0.0.1:166)
at HTMLElement.updated (compact-custom-header.js?v=0.0.1:69)
at HTMLElement.performUpdate (app-0a9a98f1.js:2)
at HTMLElement._enqueueUpdate (app-0a9a98f1.js:2)
This is all after rolling back to 0.90.2; it didn’t make a difference compared to 0.91, but was working fine when I took the snapshot I just loaded, so I’m not sure what could be causing the issue all of a sudden… There’s nothing in my HA logs, but I’m not sure what you mean by my resources section for CCH, sorry I’m still somewhat new to HA.
This is the exact config I loaded from my snapshot that I purposely titled “Everything working” when I took it, lol. It’s not a hassio snapshot; it’s a VirtualBox snapshot, so I know it’s exactly the same config I had when it was working properly, which makes this even more strange…
