Compact Custom Header
For 0.96+ you should use version 1.2.3 or newer of CCH.
I had to change from the tracker-card to HACS HACS Install and migrate all my other cards beside CCH too. But now… everything seems to be working perfektly with 0.96.3
I’m sorry again for replying before checking my CCH version… There were a lot of changes since 1.0.X and i had to adjust my CCH config as well.
So I installed 1.2.3 but as soon as I login I get this in the log:
2019-07-23 13:14:08 ERROR (MainThread) [frontend.js.latest.201907210] http://192.168.1.211:9050/local/custom-lovelace/compact-custom-header/compact-custom-header.js?v=0.0.1:211:5 Uncaught TypeError: Cannot read property 'shadowRoot' of null
And all users can see all tabs.
This is the way I installed:
  • I copied the 1.2.3 files into /local/custom-lovelace/compact-custom-header/
  • I added those lines to my ui-lovelace.yaml:
    - url: /local/custom-lovelace/compact-custom-header/compact-custom-header.js?v=0.0.1 type: module
  • I restarted HASS
E.
Since there is a 1.3.1 version would try that one instead.
Also make sure you clear your cache after you have replaced the files.
Yes!! That was it.
Thx!
E.
This solved the issue…
The ability to turn off the sidebar was built in the 96.3
answering myself for reference:
please see https://github.com/maykar/compact-custom-header/issues/177#issuecomment-514218628
issue seems to have resolved itself after a few extra restarts and cache clearances…
Sorry if this is a stupid question, is default tab configurable for the iOS app version of HA?
I’m using the config below
cch:
  options: clock
  exceptions:
    - conditions:
        user_agent: Mobile
        media_query: "(max-width: 600px)"
      config:
        default_tab: 4
I’ve tried user agent mobile, iphone ect with no luck. iPhone works on safari on the iphone (it goes to the correct tab) but not on the app, so I’m assuming it has a different user agent.
Hi sorry for being a new user for this component, but how do you remove a exception created through UI. As soon as i created it the paperbin icon disappeared. I can only seem to add another exception but not remove the one i created.
to give you some more info, I´m not running in yaml mode. Currently on the latest release 0.96.4 and running compact header version 1.3.1
Any way that the date and time can be separate things that can replace the icons? I am looking to have the date on the bar in the upper left and the time at the bar on the upper right.
As you can see I have the time on the right but would like replace the hamburger (circled in red) with just the date similar to this:
This is an awesome addition. Thanks for all of the hard work.
Sorry for the delay folks. Still on vacation for a bit, but am back behind a screen that’s not a mobile device. I’ll be addressing some of the bug reports and feature requests in the next few days, but wanted to touch on a few posts before I crash for the night.
@pjv & @mattvolp I’ll work on getting things working on legacy devices again soon.
@crankin I’m not sure the user_agent would be different in the iOS app (can anyone that uses storage mode and the iOS app check at the bottom of CCH settings to see?), but why not remove user_agent and just use the media_query? Could also be that default_tab isn’t working in the iOS app, not sure why that would be (I don’t own any iOS devices), but if one of the iOS users could chime in…
@Supersonical You can edit the config from the raw config editor after selecting “configure ui” in lovelace. You can find the exception and it’s config there to delete. I will fix up the editor so that the delete icon doesn’t get hidden when using large user_agents, but you should always be able to get away with only using a small portion of it.
I have a minor issue with CCH, the “hide_help” and “hide_config” options do not seem to work as expected in my configuration. These entries are still visible in the option menu (available when clicking on the clock, which replaces the option button)
Here is my config (latest version of the addon, latest version of Hassio (0.96.5))
cch:
  default_tab: 0
  hide_help: true
  hide_config: true
  options: clock
  clock_format: 24
  swipe: true
  swipe_animate: swipe
  swipe_wrap: false
Here is what happen when I click on the clock (replacing the option button)
Sans%20titre
Is it an expected result due to the replacement of the button by the clock ?
Default tab works fine in iOS. I think the iOS app does provide a different user-agent. Running into something similar with the button card.
I don’t use storage mode to be able to check the settings page you mentioned. I grabbed it from my NGINX logs.
[29/Jul/2019:12:50:32 -0500] "GET /community_plugin/button-card/button-card.js HTTP/2.0" 304 0 "https:///lovelace/main" "Mozilla/5.0 (iPhone; CPU iPhone OS 13_0 like Mac OS X) AppleWebKit/605.1.15 (KHTML, like Gecko) Mobile/15E148" "-"
No, hiding option menu items should work just fine even when it is a clock. Do you have any errors in logs or chrome dev tools?
No, there is no error in the log nor in the chrome dev tool.
What does your resources section look like?
Here it is :
resources:
  - url: /community_plugin/compact-custom-header/compact-custom-header.js
    type: module
  - url: /community_plugin/mini-media-player/mini-media-player.js
    type: module
  - url: /community_plugin/mini-graph-card/mini-graph-card.js
    type: module
  - url: /community_plugin/vertical-stack-in-card/vertical-stack-in-card.js
    type: js
I have changed to HACS this weekend, but I had exactly the same issue with the module installed manually.
Hmm. I was thinking that it was a cache issue and an older version without those features was cached on your system. Usually happens when manually installed and the version number isn’t included at the end of the resource url. But since you’re using HACS that shouldn’t be an issue.
I have cleared the cache anyway and used a second browser, but no luck.
I even modified the config to remove the clock but the issue persists. Could it be another breaking change of Hass.io 0.96 ?
Nah, I’m on 0.96.5 and I can hide all the items fine. HA hasn’t really changed anything in the options menu for a while. I’ve used your exact config and everything works as expected. Not quite sure what’s going on with your issue yet, but I’ll keep looking into it.
