Companion App as Media Player
Subject: Feature Request - Integration of Companion App Device as a Media Player for Piper TTS Output
Feature Request
I kindly request the implementation of a new feature that allows users to designate their Home Assistant Companion App Device as a media player. This integration would enable the routing of Text-to-Speech (TTS) output generated by the Piper TTS system to the Home Assistant Companion App Device, turning it into a convenient and flexible audio output option.
While I currently make use of the TTS notification service that utilizes the embedded TTS on my Android device, I would love to be able to make full use of the awesome Piper TTS service with the Home Assistant Companion App.
Thank you for your continued dedication to improving Home Assistant. I believe that this addition would greatly benefit the community and contribute to the platform’s ongoing success.
Please feel free to reach out if you have any questions or require further clarification on this feature request.
:blush:
Looks like theres an open issue on Github as of last year, Companion app as media_player entity · Issue #2512 · home-assistant/android · GitHub
so this request will require changes to HA core before the apps can make use of it.
Currently there are no entities provided by the mobile_app integration that allow for control. A similar request was made here to allow for the switch domain.
https://community.home-assistant.io/t/using-switches-instead-of-calling-a-service-on-android-companion-app/418004
The real question is how do we manage the communication from server to device for this, websockets is going to be battery intensive. The alternative is to use the existing notification command structure so we remain battery friendly. Not really sure whats the best way but I am not a core developer and can only speak from the android side :slight_smile:
Edit: also might be a duplicate of https://community.home-assistant.io/t/phone-becomes-portable-media-player-for-tts-notifications/467160 ?
I don’t think this requires a core change. I can make an API call to request the assist pipeline render a TTS and output a url to a wav file
We should be able to simply send a companion notification with a accessible url to an audio file, in the case of TTS a wav, and the companion app could just “play” that sound from the url. weather it’s a TTS or an alert tone.
This is not the same as the actual request for a media_player domain entity provided by the companion app, that 100% requires HA core changes.
What you are asking for is a service call to be used instead of TTS however that has an issue where the app must use a media service to play the file instead of TTS the way it is today which uses on device engine and does not need to be tied to media service as its native to android.
Ok, i see your point. I was just suggesting that the desired effect, weather or not its a media_player entity could be achieved by adding this functionality to companion. I.e. companion could play arbitrary audio url provided in the notify service call data (instead of setting the message to “TTS”, set it to MEDIA_URL, and set media_url: http://homeassistant/local/tts.wqv )
The issue i have with current TTS is my assist pipeline has a “personality” using the voice ive selected, but when i get a TTS notice away from home, it breaks immersion hearing some stranger tell me the cats water is empty.
feel free to submit a feature request for this, we actually already have the backend code for this as we use TTS for Assist already.
also if you havent already you can check to see if there is an android TTS engine with the voice you want already existing because that would give the same effect. There are multiple TTS engines you can install and select on the device. Anything you adjust in your devices TTS settings gets respected by the app, including changing the pitch and voice etc
Ok, ill make a new req. I thought id piggy back on a similar one but that was ill-conceived
After seeing this thread, I found a project which packages APKs that run Piper locally on Android. This allows you to put the same voice on the device in its TTS settings. Bonus is that all TTS on your device then gets processed locally with Piper, not just HA.
It doesn’t function as a Media Player, as the OP requested, but it solves the same problem for me.
The “medium” voice I installed was 84MB, and works pretty well.
@cabinlab
Any chance you know which apk you installed? Release v1.9.14 · k2-fsa/sherpa-onnx · GitHub
Perhaps its easier just to send the Mesage ‘play mywavfile’ and store the needed wav-files on the smartphone? So there is not much data transfer from the server to the App needed.
@ACiDGRiM did you ever make that req? Would love to follow it and see where it goes.
What’s the latest status on this? Does HA Core still need to make changes to the companion app integration to support the media_player domain?
If this is done or no longer needed, what are the next steps?
I would love to try contributing to this (I’m a software engineer with a fair amount of open source experience), but I don’t know where to start. Thanks!
Yes still waiting on that
Thanks! Where can I track that HA Core work? Is there a forum thread or GitHub Issue that I could post on? If we’re just waiting for it here in this thread, I don’t know if the right people will see this.
This is the only place for feature requests for HA core
Vote for it in the GitHub discussion: HA Android (and IOS?) Companion app as a media player target, specifically for audio files · home-assistant · Discussion #581 · GitHub
