Companion App does not connect with bad SSL certificates
I set up my Home Assistant to be available outside of local network using Cloudflare, Cloudflare add-on and Let’s Encrypt addon. Certificates are created for my external address (domain) specifically.
Every time I try to connect to a local address of Home Assistant using a web browser, I need to click “Trust” in order to connect to the address because the certificate does not correspond to the URL. Home Assistant Companion just refuses to connect at all, and there is no option to “Trust” the certificate.
This raises two questions.
  1. Is there any way to allow local IP addresses to use HTTP?
  2. Is there any way to bypass the SSL error in Home Assistant Companion CEF?
1- Using reverse proxy as nginx, you can still use home assistant local ip address without ssl and nginx will be taken care of ssl part for external connection.
2- limitation of underlying OS, nothing can be done for this.
no the app will not bypass any SSL errors, you must use a valid certificate which is not valid on a local IP address
First solution worked like a charm.
For anyone wondering:
  1. Install Nginx Proxy Manager from Home Assistant Add-On Store
  2. Configure it as in documentation
  3. In Nginx Proxy Manager Web UI, after creating a new user, go to HostsProxy Hosts → create a new host with the following configuration:
  • Domain Names: add your domain
  • Scheme: http
  • Forward Hostname: your Home Assistant local IP
  • Forward Port: 8123
  • Check Websockets Support
Then go to SSL Tab:
  • SSL CertificateRequest a new SSL Certificate
  • Check Force SSL
  • Check I Agree... at the bottom
If you want to keep your Cloudflare, click Use a DNS Challenge and configure it with your token.
  1. Edit your configuration.yaml file. Remove SSL mentions from html category and add the following:
  use_x_forwarded_for: true
  trusted_proxies:
    - 172.30.33.0/24
  ip_ban_enabled: true
  login_attempts_threshold: 5
  1. Reboot Home Assistant.
This steps made it possible to connect locally without SSL and externally with SSL.
Cheers!
Hi, I’m trying to solve the same issue with your suggesion but when putting my local ip in the domain names, nginx is getting me an error “Requested name 192.168.178.11 is an IP address. The Let’s Encrypt certificate authority will not issue certificates for a bare IP address”
what am I doing wrong?
Not what the instructions say.
Your IP goes in forward hostname. Your domain goes in domain.
I was really excited to try that, but received an “internal error” message right from the first try.
The log showed:
too many failed authorizations recently: see Failed Validation Limit - Let's Encrypt
Which is a bit puzzling, considering I just tried it for the first time.
I’ll appreciate any insights on this!
I have a pfsense router and use HAProxy for all my certificates and forwards. Has anyone tried using HAProxy for this? I got to the point where the companion app says that I have certificate mismatch.
Hi guys, I have the same issue ang I hope you can help me to solve it.
Im trying to use tailscale instead of duckdns + port forwarding.
I can connect my HA remotely while using the web browset, but while tryong to use the HA app I got a certification error.
I tried to follow the instructions above but Im not sure what should I add as the domain.
Hi there! Did you find a solution? Same issue here. Although I also got this error message:
“Some challenges have failed.”
And when I go through the steps again, it says that domain is already registered! Looks like it god registered on Let’s Encrypt, although the whole process failed and settings were not saved.
Thanks!
Sorry, I stopped working on that so I have no new news.
I moved to cloudflare and at the moment I have no SSL for the local traffic.
Thanks anyway! I fixed it deleting all https related config on configuration.yaml. That was blocking the addon somehow. Looks like SSL needs to be handle either from the config itself or the Nginx Proxy Manager addon.
For my home setup[1] this is the same recurring “SSL handshake” showstopper problem, when connecting from the internet on my phone, using the Home Assistant Android app and Chrome on Android.
However, I’m able - thankfully - to connect with Midori on Android.
Does anyone have an idea why the Midori does accept the SSL cert just fine, but HA and Chrome apps do not?
[1] home setup
  • HA img on RPi4.
  • Nginx, LetsEncrypt and Cloudflare add-ons.
  • DynDNS updated hostname.
  • Internet connections use HTTPS, local uses HTTP.
  • Cloudflare caching and security.
  • On internal, local RFC1918 network the HA, Chrome, Midori apps connect successfully to HA.
  • From the internet, only the Midori app connects successfully to HA.
My options for grey/dynamic ip
  1. register domain name from keenDNS
  2. allow remote access in the “Access to web applications” section (http, tcp/8123)
  3. copy your 4th-level domain name to HA->config->network->hostname(top section of the network settings, just domain without http://)
  4. Optional - i did it at the same time with step 3, so don’t know if it’s needed.
    set URL-address for internet - https://YOUR_DOMAIN_NAME and for LAN -
    http://YOUR_LOCAL_IP_ADDRESS
    Works fine for me with ip address in LAN and domain name(use https:// prefix) with HA companion for android.
