I just released in App Store, it should be available in a few moments
Sure, here we go: Support dynamic type on iOS (Web & App)
Itâd be awesome if you could forward it
I did hit save. Itâs with all colours and even different scripts. I recreated all my iOS actions this morning to scripts.
There is a reset button at the bottom of the screen, can you try to reset and start over? I canât reproduce this issue on my side
Hello @bgoncal I just installed the update v2024.9.1. It has fixed the problem with the script, great! However, in the control panel, I still canât operate the assistant; it does nothing when I click on it, but it does work via the widget. Is this already known to you? Thanks in advance for this great update!
Did you configure the Assist control? when in edit mode, tap on it to choose your Assist pipeline
Same issue. Still the same with icons.
Also I deleted the automations in home assistant that are related to the actions. But the actions still appear. Even after I reset configuration. And restart HA
When I put a script in the control center, I get an option to enable confirmation. However this doesnât seem to do anything. I can only see confirmation mentioned in regards to the apple watch news. Is it not supposed to be possible to have confirmation in the regular control center or is it a bug that itâs not working?
Those are 2 different things, Apple Watch has a âconfirmation required before runâ, control center has âconfirmation notification after runâ
Weird, must be some issue while updating your watch app, reboot your watch and reinstall HA app on it to see if it shows up
You need to delete the actions itself not only their automations
Thanks for this fantastic update!
@bgoncal, one question: are âswitchâ entities in roadmap for future releases?
It would be great to have switch control besides lights.
I was able to remove the iOS actions as they were coded in the configuration.yaml file.
However the icon colour issue still persists and I tried on my wifeâs phone and the same issue. Set the colour and save and still shows black.
After watched video that @wgumaa provided. I confirmed it is the same issue I faced. Even re-install the Home Assistant app version 2024.9.1 on my Apple Watch running on watchOS 11 and iPhone 15 pro running on iOS 18 and hit the reset button to start over configure, nothing has been changed. I notice when change the icon or background color to default blue or default green, both of them respect the color change, but when change both of them to default orange or default yellow or custom color, the color is always switched back to black.
@khuntop never thought about those colours, so I tried and confirm your findings.
Almost same setup. Latest watchOS and iOS. Both on iPhone 14pro and 12pro.
Great update for iOS companion app, thank you a lot guys. This way one do not need to go into homebridge in order to have icons on control screen. so directly from Home Assistant, thats nice.
One question: how to use new âlocation permission categoryâ and what is it useful for?
Yes, coming soon
In my case I use it to tell my parents and partner âhey guys, you have to âallow alwaysâ HA permission so automations work well" hahaha because iOS sometimes says âthis app has been using your location in background, do you want to allow only during app usage?â and then they tap on it because well⊠for many apps it makes sense but not for home assistant
This update to iOS companion up is really useful. Thank you for all the work done.
There was regression introduced by the latest iOS app update (non-preflight version). There are 2 main issues:
- âNo watch configuration available. Open the iOS app and create your configuration in the Companion app settingsâ â this one makes the iOS actions configured on homeassistant server side (yaml) unusable as none of the actions is displayed on the watch HA app start screen. I was able to get around this by going in the HA iPhone app to Settings - Companion App - (Apple Watch) Configuration and disabling Show Assist (at the bottom) and then hit Save on the top right of the screen.
- The apple watch action text color for all actions is no longer accurately displayed. Instead the color white #FFFFFF is used for all actionsâ text.
