Companion app not detected by Mobile App integration
So i installed and configured the companion app on my S22 Ultra, and the integration does not see my companion app install
Companion app is pointed to the nabu casa url
do you have either default_config or mobile_app in your configuration.yaml? sounds like you don’t, you need either one or the other.
my bad for not noting that down already
yes i have default_config in my config.yaml
looks like a duplicate of https://github.com/home-assistant/android/issues/2220 if possible try to get us the requested logs mentioned in the issue.
i tried the easyest thing first: delete the app and reconfigure it with the local adress
it immideatly started the integration setup
now i only have to change the adress to the remote one and its finished
