Companion app service call widget fails
Can anyone decipher this? Service calls are not going through from the widget.
06-21 18:10:00.660  4768  4768 E ButtonWidget: Could not send service call.
06-21 18:10:00.660  4768  4768 E ButtonWidget: io.homeassistant.companion.android.common.data.integration.IntegrationException: Error calling integration request call_service
06-21 18:10:00.660  4768  4768 E ButtonWidget: 	at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.callService(IntegrationRepositoryImpl.kt:279)
06-21 18:10:00.660  4768  4768 E ButtonWidget: 	at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl$callService$1.invokeSuspend(Unknown Source:15)
06-21 18:10:00.660  4768  4768 E ButtonWidget: 	at kotlin.coroutines.jvm.internal.BaseContinuationImpl.resumeWith(ContinuationImpl.kt:33)
06-21 18:10:00.660  4768  4768 E ButtonWidget: 	at kotlinx.coroutines.DispatchedTask.run(DispatchedTask.kt:106)
06-21 18:10:00.660  4768  4768 E ButtonWidget: 	at android.os.Handler.handleCallback(Handler.java:942)
06-21 18:10:00.660  4768  4768 E ButtonWidget: 	at android.os.Handler.dispatchMessage(Handler.java:99)
06-21 18:10:00.660  4768  4768 E ButtonWidget: 	at android.os.Looper.loopOnce(Looper.java:226)
06-21 18:10:00.660  4768  4768 E ButtonWidget: 	at android.os.Looper.loop(Looper.java:313)
06-21 18:10:00.660  4768  4768 E ButtonWidget: 	at android.app.ActivityThread.main(ActivityThread.java:8757)
06-21 18:10:00.660  4768  4768 E ButtonWidget: 	at java.lang.reflect.Method.invoke(Native Method)
06-21 18:10:00.660  4768  4768 E ButtonWidget: 	at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:571)
06-21 18:10:00.660  4768  4768 E ButtonWidget: 	at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1067)
06-21 18:10:00.661  4768  4768 D CompatibilityChangeReporter: Compat change id reported: 147798919; UID 10514; state: ENABLED
06-21 18:10:00.668  4768  4768 V Toast   : show: caller = io.homeassistant.companion.android.widgets.button.ButtonWidget$callConfiguredService$1.invokeSuspend:330
