Hi all. I’ve seen a 5 year old thread on using the Android Companion app with a Tor .onion URL but it doesn’t seem like it works the same way anymore?
I have the Tor add-on in my HA at my house, I have used torbrowser to connect to it ok.
I have the companion app on my Android phone. I have orbot installed and RethinkDNS app installed.
RethinkDNS sets up a virtual VPN and then intercepts stuff and filters/routes/etc. One option it has is to route certain apps over the orbot HTTP proxy.
I’ve set HomeAssistant to be routed over the Orbot HTTP proxy. And I set my external URL to http://blablablabla.onion the same blablabla that I have successfully used to connect via torbrowser on my laptop.
But the companion app says
“Webpage not available… ERR_NAME_NOT_RESOLVED”
It seems it doesn’t like the .onion URL. Has anyone gotten this working?
NOTE: I just tested my TOR setup by telling Rethink to route Firefox through Tor, and then loading a blog I visit a lot, it went through cloudflare’s “test if you’re a human” and then blocked me because my IP is on some block list (ie. the exit node of the Tor). As soon as I change Firefox back everything works. so Rethink IS routing working with orbot.
