Compare if sunrise before or after 7:15
For my automation to open the blinds in the morning, I want the blinds to open no earlier than 7:15 if the sun has already risen. Is sunrise after 7:15, the blinds should open at sunrise. I already have the following automation:
alias: Gordijnmanager
description: ""
  - platform: time
    at: "07:15:00"
  - platform: sun
    event: sunrise
    offset: 0
    enabled: true
  - device_id: eaf23ea82bae8a3cfdb25647eb694253
    domain: zha
    platform: device
    type: remote_button_double_press
    subtype: button_2
  - platform: time
    at: "22:00:00"
    domain: zha
    platform: device
    type: remote_button_short_press
    subtype: button_2
  - platform: sun
    event: sunset
    offset: 0
  - platform: state
    entity_id:
      - media_player.chromecast_huiskamer_2
    to: "on"
    id: Sluit huiskamer
  - platform: state
    entity_id:
    to: "off"
    id: Open huiskamer
  - platform: state
    entity_id:
      - media_player.kpn_diw7022
    to: "on"
    id: Sluit huiskamer
  - platform: state
    entity_id:
    to: "off"
    id: Open huiskamer
condition: []
  - choose:
      - conditions:
          - condition: trigger
            id:
              - Open
          - condition: template
            value_template: ""
        sequence:
          - service: cover.open_cover
              entity_id: cover.rolgordijnen
            data: {}
            metadata: {}
            data: {}
              entity_id: input_boolean.rolgordijn_huiskamer_door_manager
      - conditions:
            id:
              - Sluiten
        sequence:
          - service: cover.close_cover
            metadata: {}
            data: {}
          - service: input_boolean.turn_off
            data: {}
      - conditions:
            id:
              - Sluit huiskamer
        sequence:
            metadata: {}
            data: {}
              area_id: huiskamer
      - conditions:
            id:
              - Open huiskamer
        sequence:
            metadata: {}
            data: {}
              area_id: huiskamer
My idea is to have a condition at the first option and check if sunrise is before or after 7:15 using a template. So, if sunrise <= 7:15 result should be false, otherwise true. I can’t find how to get the current time and compare it to 7:15.
Just add a time condition (where you have []) for after 07:15. It will affect all the other triggers though. If you don’t want that, break your automation up into two ones. One to deal only with the morning routine and another for the rest.
Well, I thought about that, but you already know what happens: I have to split the automation. It’s my goal to keep this all together in one, if possible. And just with typing this and your answer, I have found the answer to my own question. To check in Option 1 if the time is after 7:14:59.
For anyone interested, here the code:
description: ""
  - platform: time
    at: "07:15:00"
  - platform: sun
    event: sunrise
    offset: 0
    enabled: true
    domain: zha
    platform: device
    subtype: button_2
  - platform: time
    at: "22:00:00"
    domain: zha
    platform: device
    subtype: button_2
  - platform: sun
    event: sunset
    offset: 0
  - platform: state
    entity_id:
    to: "on"
    id: Sluit huiskamer
  - platform: state
    entity_id:
    to: "off"
    id: Open huiskamer
  - platform: state
    entity_id:
    to: "on"
    id: Sluit huiskamer
  - platform: state
    entity_id:
    to: "off"
    id: Open huiskamer
condition: []
  - choose:
      - conditions:
            id:
              - Open
          - condition: time
            after: "07:14:59"
        sequence:
            data: {}
              entity_id:
                - input_boolean.rolgordijn_huiskamer_door_manager
            data: {}
      - conditions:
            id:
              - Sluiten
        sequence:
            metadata: {}
            data: {}
              entity_id:
            data: {}
      - conditions:
            id:
              - Sluit huiskamer
          - condition: state
            state: "on"
        sequence:
            metadata: {}
            data: {}
              area_id: huiskamer
      - conditions:
            id:
              - Open huiskamer
          - condition: state
            state: "off"
        sequence:
            metadata: {}
            data: {}
              area_id: huiskamer
Ah, that pesky “issue”.
Have a look here: Time condition - inclusive or exclusive? - #25 by parautenbach.
Personally, to avoid any uncertainty, I only use template conditions in cases like yours (I forgot about the above).
Got it. I didn’t give the full set of triggers my full thought, which is why I stated it open-ended. Sometimes the complexity of a single automation isn’t worth it. My own preference is for smaller, specific automations, but I certainly have large, complex ones too.
